MrOizo wrote:In the Supra, i would swerve left, right, left, right and the noise would go loud, quiet, loud, quiet.
With the wheel in the air, can you get any movement side-to-side in either vertical or horizontal directions?
Also, check that the nut on the end of the axle isn't loose - can be forgotten/overlooked when reassembling after doing something like clutch.
Lloyd wrote:Why would you take the hub nut off and wiggle it? That's the only thing actually holding the 2 inner races together and stopping play in most cases. Almost any FWD that you take a hub nut off will have play.
pc wrote:Lloyd wrote:Why would you take the hub nut off and wiggle it? That's the only thing actually holding the 2 inner races together and stopping play in most cases. Almost any FWD that you take a hub nut off will have play.
Not in my experience, note i'm only wiggling it by hand, not with any weight on it or with a bar etc.
Crucible wrote: But the cv nut holds the inner races together and holds the flange in place, you will always have play as there is nothing to keep it intact. If you were to leave the cv nut off and drive down the road the wheel would fall off.
Lloyd wrote:No, we're all talking about front bearings in a FWD.
pc wrote:Lloyd wrote:No, we're all talking about front bearings in a FWD.
...So when you install a brand new bearing in a front drive you can feel play in it before you put the hub nut on?
pc wrote:Either way... If there is play without the hub nut done up, then something needs replacing.
Users browsing this forum: No registered users and 26 guests
