Gull's E10 fuel
Gull's E10 fuel
Postby cat007 » Sun Mar 23, 2014 10:31 pm
So - since this has been on the market for a few years now in NZ, what are peoples real life experiences with it?
Would be keen to hear from people in high comp N/A's to high boosted engines to basic every day cars....
Re: Gull's E10 fuel
Postby 2jayzgte » Mon Mar 24, 2014 7:02 am
Is this fuel any different to Mobil's Synergy 8000???
2jayzgte
Re: Gull's E10 fuel
Postby loudstealthGT-Four » Mon Mar 24, 2014 11:04 am
Just started using E10 a couple weeks ago, mixing 10% ethanol with 95, as there is no easy supply of 98. Seems to run better, though have no actual evidence of this. And it smells pretty good too :D
loudstealthGT-Four
Re: Gull's E10 fuel
Postby Townace » Mon Mar 24, 2014 4:42 pm
My late model cefiro daily loves the stuff. Lots of pinging on part throttle if I run it on any other fuel.
Returns better economy than any other fuel either which is the confusing part
Townace
Re: Gull's E10 fuel
Postby QikStarlie » Mon Mar 24, 2014 5:34 pm
just a touch better than bp 98 in my experience, but not much at all in it. this is in a turbo car pushed to its octane limit. run it in my hi comp na 4age also.
best stick to what your car is tuned for. will run a little leaner on e10 than bp98.
QikStarlie
Re: Gull's E10 fuel
Postby Heylin » Thu Apr 10, 2014 1:33 pm
Gary Capper tuned our Legacy GT and advised to go for BP98 over E10 (Gulls 98).
Heylin
Heylin
Re: Gull's E10 fuel
Postby edwagon » Thu Apr 10, 2014 2:09 pm
I always run either BP 98 or E10 in my Aristo
I think it goes better on e10 - feels like more part throttle torque
edwagon
Re: Gull's E10 fuel
Postby Leon » Thu Apr 10, 2014 2:16 pm
WRX used a lot more petrol with E10 than even on Z 95.
Like more than 10% more
Re: Gull's E10 fuel
Postby Bazda » Thu Apr 10, 2014 5:11 pm
E10 is not very consistant in the octane rating i've been told.
So if you tune on E10, another batch could out the tune out.
Re: Gull's E10 fuel
Postby Lith » Mon Apr 14, 2014 1:05 pm
Bazda wrote:E10 is not very consistant in the octane rating i've been told.
For what it's worth a car I tuned for flex fuel has had Mobil 98 poured into an empty tank and measured very near 10% ethanol - though one of the things that should really be obvious anyway, but becomes easy to appreciate is that having straight petrol in a tank then filling up with an ethanol blend doesn't suddenly bump what is in the tank to that ethanol percentage, even filling up on E85 into a tank which *seems* nearly empty of straight petrol usually tends to result in maybe slightly over E70 in the tank.
Say for sake of argument if you are getting ready for a dyno tune and decide to fill up on Force10, you could have say 15 litre of petrl still in the tank then you pour a further 30litres of E10 in there to get ready for your dyno tune... if you ponder the volumes involved:
Original 15litres petrol = 15litres petrol (funnily enough being 0% ethanol :D )
New 30 litres Force10 = 27 litres petrol (90% petrol) + 3litres ethanol (10% ethanol)
So you end up with 45litres of fuel in the tank, 3 litres of which are ethanol - which turns out as "only" 6.6% ethanol, which can have a tangible effect on the tuning requirements.
2007 Mazdaspeed Axela
Lith
Re: Gull's E10 fuel
Postby l SIC l » Wed May 14, 2014 9:58 pm
When the R35 arrives I'll install the Cobb V3 Accessport and have maps for 95, 98 and E85. With the 98 tune, do you think I should run two separate maps for BP 98 and Gull 98 though, or won't that be necessary?
R35 GT-R 'Black Edition' 750HP
86' AE86 GT Apex
96' S2 RZ Supra
R34 GT-R V-Spec
l SIC l
Re: Gull's E10 fuel
Postby Lith » Wed May 14, 2014 11:20 pm
So long as it isn't too aggressive it should be fine - there are plenty of cars running around which run on both perfectly reliably, I'd just tune it on BP98 and make sure there is a little bit of "fat" in the mixtures in case it ends up running E10, closed loop lambda should cover most of the cruise around stuff and really it won't make a big difference.
Lith
Re: Gull's E10 fuel
Postby l SIC l » Thu May 15, 2014 1:32 am
Good point. I think it can run 4 maps anyway (and can switch between them in 40 seconds or so), so I'll see if it's necessary from my tuner whether or not to bother with running a second 98 map for E10. I think the main issue was with pre-06' motors developing seal leaks running E10, wasn't it?
86' AE86 GT Apex
96' S2 RZ Supra
R34 GT-R V-Spec
l SIC l
