Do I need to pull them right out again and regrease, or if theres play in there is it replacement time?? Or am I just barking up the wrong tree?
Boosted_162 wrote:So if I spin the wheel forwards it only does it once, but if I rock it back and forwards it happens everytime it changes direction.
Crucible wrote:Do the pads sit tight in the locating bracket? If they are loose you will get a clunk with them moving. Is there any dowels on the pad steel backing? As in piston or outer part of caliper not sitting flat against the pads?
More likely the case with non oem pads, have been caught out once or twice.
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
