Fortune Auto USA AE86 Coilovers
Postby Bazda » Fri Aug 22, 2014 9:45 am
We are excited to announce that we will be releasing the Toyota AE86 application very shortly. We also will have this application available in several different configurations.
For the front shocks customers can opt for a plug and play solution with a OEM style spindle setup or a more economical weld up set up that re-uses the OEM spindle and requires welding and fabrication.
For the rear shocks customers can opt for a OEM style separate spring and shock setup or a true coilover setup for the die hard racers and drifters.
NOTE: True rear coilover setup requires extensive modification to the rear strut towers. The towers must be reinforced.
Fortune Auto USA is currently under going testing to get the valving specs spot on for this car.
www.fortune-auto.com
Re: Fortune Auto USA AE86 Coilovers
Postby Bling » Tue Aug 26, 2014 7:45 pm
How do the bolt in kits with spindles work with certs? Also, any ideas on ball park pricing for those yet?
So pretty!
Postby Bazda » Tue Aug 26, 2014 8:42 pm
Bling wrote:How do the bolt in kits with spindles work with certs? Also, any ideas on ball park pricing for those yet?
So pretty!
Im requesting we get the parts not welded and get it done in NZ. It will have to be crack tested as well which costs $115.
The kits are looking to be around $1879 incl with spindles. And $1699 without
Postby Bling » Tue Aug 26, 2014 11:28 pm
Sweet thanks for the info, some pretty nice kit aye!
Return to Toyspeed Sponsors
