83 Corona Carby
83 Corona Carby
Postby RollaGT_87 » Sat Oct 25, 2014 1:44 pm
Hey lads and lasses,
Just wondering if anyone can recommend the easiest way to get a bit more go out of a 3T. I'm thinking carby, but don't even know where to start, or what has to be done to get the most out of it. Do ya just stick a 2L carby on and wow wizzo you have mo power? Or do you spend 8 years tinkering with a set of feeler guages, upgrade the fuel pump, and call a wizard? Basic as rundown if ya have the time to help out a rookie.
Chur
Tip for successfull rally driving: Don't sink you're car in the first pond to catch your eye.
"That's a f**kin' b*gg*r innit??"
"We were a bit hot, thought we'd take a dip n cool off"
RollaGT_87
Re: 83 Corona Carby
Postby MAC_HATER » Sat Oct 25, 2014 4:15 pm
I converted my '83 corona to a 3T EFI with friends, it took 6 months and countless problems
for all of that the butt dyno felt a little bit better below 3000rpm, otherwise no change haha
but the chrome intake runners were worth it!
You could look at a hotter cam? I recall mine being pointless over 4500rpm - some more life after that cant be bad?
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Re: 83 Corona Carby
Postby RS13 » Mon Oct 27, 2014 12:13 pm
PM fangsport, from memory he has a bit of experience with modifying T-series engines.
RS13
Re: 83 Corona Carby
Postby Dell'Orto » Mon Oct 27, 2014 3:47 pm
Put a big cam it in 8)
Re: 83 Corona Carby
Postby fangsport » Mon Nov 03, 2014 8:17 pm
there no such thing as 'too big a cam....just not enough motor " !!
clean the ports
skim the head
throw factory carb in the bin
put a big cam in it !!!
fangsport
Re: 83 Corona Carby
Postby RS13 » Mon Nov 03, 2014 8:33 pm
Weber 32/36?
RS13
Re: 83 Corona Carby
Postby fangsport » Mon Nov 03, 2014 10:32 pm
RS13 wrote:Weber 32/36?
alright for road and mild club car.
i had a 40/40 on mine for a while, but bit thristy for a daily.
sidedrafts if you can afford them, had DHLA40 , shelved them to collect dust cos i found a set of DHLA45's cheap and they are a massive improvement
fangsport
Re: 83 Corona Carby
Postby MAC_HATER » Mon Nov 03, 2014 10:57 pm
you could be a real sicko and track down some angrier pushrods that will deal with more revs too
get the wee sucker singing to 7500rpm, i know mine sounded like a dying cat anywhere between 5500 and 6000rpm haha
i suppose at that point you might as well whack on a 2T-G head and go twincam :D
MAC_HATER
Re: 83 Corona Carby
Postby fangsport » Tue Nov 04, 2014 12:08 am
MAC_HATER wrote:you could be a real sicko and track down some angrier pushrods that will deal with more revs too
never knew the pushrods were the weak link ??
got proof ???
as i have never bent one, and neither did Keith Pun when he used my car for D1nz and he was pulling huge numbers
fangsport
