CAS cable looks to be solid, and actually there is no noise on the traces at all. What might be causing a problem is the last tooth, which is giving half the peak that the rest are. I did nick that tooth a bit while grinding off the missing one. Looks like I need a new trigger wheel.
First, cranking with no spark plugs, to remove variation.
Second, with plugs in.
That said, I did get it to run for about 5 seconds, albeit very badly on what sounded like 2 cylinders!
Edit: New plan, Im going to grind off the rest of the damaged tooth and set the ECU to expect 2 missing teeth.
