ST215 coil-on-plugs pinout
Postby Vertigo » Sat Nov 29, 2014 12:42 pm
Hey guys, Im after the pinout for the 90919-02227 coil packs, as used in the ST215. Round top with four pins.
TVIS just kicked in, yo!
Vertigo
Re: ST215 coil-on-plugs pinout
Postby Grrrrrrr! » Sat Nov 29, 2014 7:59 pm
Can't find the pinout, but I am pretty sure it was not the same as the other Toyota 4pin COPs. If you do find it can you post a link here, i'll be needing it soonish.
If anyone with a caldina has the intercooler off a few photos of the plugs would help, 3 wires should be the same colour, with the trigger wire being a different colour for each cylinder.
Grrrrrrr!
Postby Grrrrrrr! » Sat Nov 29, 2014 9:53 pm
Okay, the beams redtop uses the same style COP, outside pins are power, centre 2 are signal.
so with the connector on the COP pointing towards you and the body pointing down
GND(to head) IGT(ECU) IGF/ION(Not used) +12V
Grrrrrrr!
Postby Vertigo » Sun Nov 30, 2014 12:23 am
Excellent thank you, confirmed that works fine.
Vertigo
