1jzgte randomly won't fire on 6
Postby iamawesome » Sun Dec 21, 2014 11:49 am
Hey guys
so last week my supra's battery went flat and I had to charge it. Now when it turns on it fires on 6 then just starts dropping cylinders and stalls after about a minute. Iv tried new plugs, unplugged the emanage ultimate, and the obvious things like resetting the ecu. The speedo cable isn't plugged in since I broke it but I don't see why that would do anything? Was running 100% fine the week before
any help appreciated
iamawesome
Re: 1jzgte randomly won't fire on 6
Postby phoenix » Sun Dec 21, 2014 1:10 pm
Does it just happen on cold starts?
Is it fouling the plugs to the point of misfire?
Have you taken it for a thrash since charging the battery?
Have you gassed it up recently?
ECU should have already been reset when you disconnected the battery to charge it - unless you charged it while it was still connected?!
11 second Honda
phoenix
Postby iamawesome » Sun Dec 21, 2014 4:38 pm
It's to the point where it won't idle. Couldn't possibly drive it. Yeah I know but for the sake of pulling a fuse out I just did it anyway . But I think the ecu has pooped its self again. It was running 100% fine last week and even did a dyno run the other week. After around 2 minutes it just dies but then I can turn it on and it will run then just drop cylinders against
iamawesome
Postby Mr Ree » Mon Dec 22, 2014 10:31 am
Do you have a spare ecu you can try, or borrow one from another 1JZ?
wak thud gush!
Mr Ree
Postby iamawesome » Mon Dec 22, 2014 12:02 pm
Yeah picking one up today. Fingers crossed it works
iamawesome
Postby iamawesome » Mon Dec 22, 2014 8:47 pm
All sorted. Was the ecu as suspected
iamawesome
