gsr engine alternator not charging
Postby jacobrjett » Wed Dec 24, 2014 3:23 pm
trying to figure out why alternator isnt putting out any charge, its been replaced twice and theres still no charge, first one from pick a part second one is known working bought from mitsubishi,
checked voltage straight from the alternator and at the terminals, nothing comes from it
anyone know what the blue and red wires do going to the alternator? im wondering if its something to do with these, the car in question is a mirage with a gsr conversion, so was wondering if these got damaged at some point (not as far as i can see though). is there a way to configure these to turn the alternator on or off or something, at least to check the alternator can actually put out a voltage?
there seems to be a lack of good 4g93t wiring diagrams online (or at least a lack in my search skills)
jacobrjett
Re: gsr engine alternator not charging
Postby jacobrjett » Wed Dec 24, 2014 3:31 pm
pretty sure the blue is an earth so if i ground that and give 12v to the red one will that work to test out the alternator? i dont want to accidentally stuff it up so thought id ask, also if that works would it be that bad to ground the blue one and splice the red one into the ignition...?
jacobrjett
Postby Alex B » Wed Dec 24, 2014 5:21 pm
I like how you're quite happy to play with 240v but 12v is a no no. :lol:
Postby Bling » Thu Dec 25, 2014 12:01 am
Are the blue and red wires factory?
Really need a wiring diagram I guess, or a mitsi forum :P has it never worked or has this issue only recently surfaced? Could be less stressful to just get an auto sparky to take a look and see what is going on. Anything else is just guess work, and may cost you more in the end.
Postby rollaholic » Fri Dec 26, 2014 4:33 pm
does it run ok otherwise? with a jumper on presumably. battery light on?
i'd put money on it being something done during conversion
Postby jacobrjett » Fri Dec 26, 2014 6:53 pm
runs mint as otherwise, runs and boosts fine, zippy little car when you put a charged-up battery in it, that was my thought too, apparently it used to run fine but that could be a fib from the previous owner, it came like this
the blue and red wires appear factory, looks like an unmodified plug, the red one goes to the fuse box and then goes into a bunch of wires going under the drivers guard, but the blue one goes into another bunch of wires through the firewall that has a red one hanging loose... ive thought of connecting them but with my level of knowledge that would just be connecting random loose wires together
240v is all good :lol: that turned out to be a problem with the sockets, not with my wiring :)
jacobrjett
Postby Dell'Orto » Fri Dec 26, 2014 10:04 pm
When you say the second one was a known working one, have you had it bench tested? Have bought many an alternator from a wrecker that was "known good" (like they even test them!) that was dud.
Wouldn't have thought the alternator wiring would have needed to be fiddled with for a motor swap
Postby 85AW20v » Sat Dec 27, 2014 9:07 am
If you google "mitsubishi alternator wiring" and look at the images you should be able to work it out.
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Mon Dec 29, 2014 11:17 pm
Post the alternator part number and I should be able to give you a diagram.
But if there is a 2 pin plug on it it will probably be Warning light to one terminal,
and the other is sensing which is battery,
If you get the two round the wrong way you can damage it.
Pretty sure it wont have an earth connection apart from the body housing.
Postby rollaholic » Thu Jan 01, 2015 9:44 am
is the battery / charge light on the dash full time?
Users browsing this forum: Bing [Bot] and 25 guests
