Driveshaft loop position
Postby DeeCee » Sat Jan 03, 2015 12:22 pm
Good morning all,
Looking for a little guidance :)
Blue lines indicate position relative to the centre of the joint.
Is the loop acceptable in this position as the flat bar and reinforcement plate would be against flat metal vs contoured (can't distinguish from pic sorry) and we have to avoid interference with the handbrake cable. Just want to ensure that the position is correct to ensure that in the event of a failure, that the loop would function as required.
Cheers Dave
GT Four Adovansu
DeeCee
Re: Driveshaft loop position
Postby BlakeNZ » Sun Jan 04, 2015 5:21 am
it has to be within 150mm of the red line, so your image looks fine, at least from what i can see from the photo.
BlakeNZ
Postby DeeCee » Sun Jan 04, 2015 12:27 pm
I thought it would be fine, but wasn't sure if the loop had to be behind the shaft to union weld joint or not. Cheers
GT Four Adovansu
DeeCee
Users browsing this forum: Bing [Bot], Google [Bot] and 25 guests
