Bolt in roll cage
Post Reply
vr4boy
Bolt in roll cage
Post by vr4boy »
I have had a bit of a look through the Motorsport manual but didn't find the answer, what I want to know is can I use a bolt in half cage for club sport events? And secondly if I can, can I mount harness's to it?
Thanks
Dan
1995 ae101 levin st 20v
Contact:
Re: Bolt in roll cage
Post by matt dunn »
I am not sure on the 1/2 cage stuff, and what you can run where from the top of my head,
but I take it that you know that a bolt in cage must be bolted to foot plates that must be welded into the car,
so even a bolt in cage needs the same area footplates welded in as a standard cage.
Post by Dell'Orto »
How would GT2 Porsches get around this? Their cage looks like it just bolts into the bodywork?
Contact:
Post by matt dunn »
Dell'Orto wrote:How would GT2 Porsches get around this? Their cage looks like it just bolts into the bodywork?
Pretty sure they wont, just looks like it.
When I got a car approved with a bolt in cage,
you had a plate say 100mm x 100mm that was the foot of the cage,
you also had another plate the same size 100mm x 100mm that was welded to the car.
When you place them on top of each other and bolt them up it looks like the cage is just bolted to the floor,
but it is not.
There is also the possibility that the one that is welded to the car is welded under the car, and the cage is bolted to the top,
so the car panel is sandwiched in the middle.
That was a few years ago, but I can't imagine they have removed the need for the extra welded in plate.
Post by strx7 »
Factory fitted item
vr4boy
Post by vr4boy »
Yes I'm aware I need to weld a plate to the floor to bolt it to. Just looking into options in regards to added safety and something to attach my harness to
Contact:
Post by matt dunn »
Does the bolt in cage have a bar between the rear stays? or is it an option to add one?
vr4boy
Post by vr4boy »
It has the main hoop, with two rear stays and a diaganol bar from hoop to bottom of one rear stay with optional harness bar. All bars bolt together.
vr4boy
Post by vr4boy »
Post by Leon »
Can't be used in competition.
Non approved joints.
The ad is bastardly written ... as it implies it is useful as it says Motorsport approved tube.
What it doesn't say, is "Scrutineer will wee himself laughing if you turn up with one of those".
vr4boy
Post by vr4boy »
Haha awesome Leon, I had a feeling this could be the case. Think I will just stop being tight a get a proper cage.
touge_ae101
Post by touge_ae101 »
Not entirely accurate Leon. My rally car has a bolt in cage which doesn't inspire a lot of confidence..
There is a design guideline for bolt in cages somewhere (don't ask me where sorry) but generally it's so much more work it's just not worth it.
Bolt in cage would have to be specifically built and designed to the regs so you can prove the wall thickness, bend deflection etc etc.
Edit: Hah just saw TM ad.. Bit of a play on words there with being made from roll cage tube not approved design.
Post by Leon »
touge_ae101 wrote:Not entirely accurate Leon
My reply was specific to the Trademe ad cage.
Trust me, I know rollcage rules ;). 5.5 years as the guy who did all the MotorSport NZ roll cage homologations. --->
Post Reply
