Stott69 wrote:As for the timer idea, is that not for the oil side of things? I was under the impression that a turbo timer was so the turbine had stopped spinning be for you stop oil flow over the shaft and bearings?
Dell'Orto wrote:I guess as long as it isn't passing through so quickly it doesn't get a chance to draw as much heat out as it might otherwise do, can't be a bad thing.
What do Evos use sizewise?
sergei wrote:Stott69 wrote:As for the timer idea, is that not for the oil side of things? I was under the impression that a turbo timer was so the turbine had stopped spinning be for you stop oil flow over the shaft and bearings?
no, that's for the oil not coke in the housing. Pointless for water cooled turbo.
Al wrote:sergei wrote:
Oil won't coke it's not 1985 anymore.
Turbo timers just waste gas.
The only time my engine bay fan came on in the AW was in the pits after hard track use on a hot day and you're right - the cool down laps didn't help dissipate much heat except for maybe the brakes and mine is NA not turbo.Grrrrrrr! wrote:...... thats a shit-ton of heat to get rid of, and MR2s aren't known for great engine bay airflow. I don't think the <2 minute cruise back to the pits is going shed all that heat by itself. Turbo timer will be getting used for at least another minute once back in the pits.
