Hi all. For a while now I've had problems with a really high idle on my Cynos so today I took the drastic measure of removing the throttle body. I found the waterway completely blocked in the IAC and up into the TB so I cleaned all the gunk out with carby cleaner. The spring mechanism in the IAC was also seized, so I took the end cover off and sprayed it with cleaner inside and worked the spring manually from the end with a screwdriver - it's as smooth as silk now and tested operation by boiling / chilling the thermostat end.
What I need to do now is get the baseline idle set. I read somewhere about jumpering the diagnostic port to take it out of closed loop to set the baseline - is this necessary ? If it is, I know how to jumper because I checked for codes the other day ( none found ). Also, which screw should I adjust in which order - there's a set screw in the TB and also a air bleed type screw on the firewall attached to hoses.
Thanks
