A few niggles remain. It still doesn't like starting sometimes, the starter cranks along well but it won't fire easily unless I give it a bit of gas. I haven't had to start any other EFI car with my foot slightly on the gas. I have been told this could be a map sensor wiring issue? The wiring going into the map sensor looks intact. Idle is a little rough but doesn't hunt up and down or idle high. Sits at 1000rpm or so.
When giving it a few revs, like a quick second gear run up to redline, the temp needle jumps around sometimes, like straight up to hot then back to cold, then back to normal position.
Tonight it was wet out so I put on the wipers, which for some reason were incredibly slow, even on the fast setting, they were crawling up and down the windscreen. The stereo turned off. So I pull over, the stereo comes back on, and the wipers are back to normal.
What could my electrical gremlins be?
