whynot wrote:...turbo sitting extremely low...never had any problems with oil return...I get some oil coming from the sump...managed to get away with it...
whynot wrote:Someone else might be able to confirm this but I thought having back pressure on the drain would lead to oil leaking through the turbo seals not destruction of the journals or bearings in such a short time.
The seals in almost all turbos today are piston ring seals. They look like piston rings that
are compressed when they are installed to leave minimal gap between the ends of the rings and
around the rings. This forms a torturous path for the oil to prevent leakage into the air passage.
Most performance turbos use only a single piston ring on the compressor and turbine sides because
they do drag the rotation of the turbo which reduces mechanical efficiency. In applications sensitive
to oil leakage for emissions, etc. it is not uncommon for 2 piston rings to be used on both the
compressor and turbine sides.
On the compressor side, generally there is some kind of oil splitter which throws oil away from
the seal as it is spinning. Because the piston rings and the splitter are dynamic seals, when the
turbo is spinning faster, the better the seal operates.
The oil leak is driven by pressure, like any other fluid flow. When the oil pressure inside the center
housing of the turbo is higher than the air pressure outside of the seal, the oil wants to travel outside
to the air passage. The air that is holding the oil back on the compressor side is the compressor
outlet pressure and for the turbine side, it is the turbine inlet pressure. That is because it is the
air pressure that is behind the wheel (depends on wheel geometry and air pumping by the wheel too).
This is why turbos leak more at idle/low load conditions and leak less when under full load/boost.
Vertigo wrote:Thats good to know. I now have a new turbo with new much higher flanged manifold. Should be ideal.
