4AGE turbo fail
Re: 4AGE turbo fail
Postby whynot » Tue May 24, 2016 1:46 pm
Could you post a few pics of your clearance problems? We might be able to suggest a few different ways around the problem. What part of the compressor is hitting the clutch parts? Is it the outlet or the housing?
I was suggesting the e56 clutch slave as it may be a different size or shape to the aw11 which could be what you need. Perhaps re doing the hardline is an option? I'm just thinking of mixing and matching fwd parts to get the required clearances with bolt on bits only.
whynot
Re: 4AGE turbo fail
Postby Vertigo » Tue May 24, 2016 2:26 pm
Roger that. Ill try it tonight to see what the issue with (currently just going by what the workshop told me). Pretty sure he said it was the slave cylinder that was fouling. Will report back soon.
TVIS just kicked in, yo!
Vertigo
