AE101 FX won't start - electrical
Postby joff_nz » Tue Jan 31, 2017 7:56 am
Howdy
Having an intermittent issue with my FX not starting. When I turn the key the dash lights etc all come on fine, but nothing when I go right over to ignition. Usually it is fine, but sometimes I get this problem.
In the last few days though it's getting worse. It will start fine after I take the key out & try again a few times.
Seems something like a switch in the ignition, relay or similar failing.
Have googled but most info I can find relates to mechanical problems. Help pls
Long time reader
joff_nz
Re: AE101 FX won't start - electrical
Postby GDII » Tue Jan 31, 2017 8:50 am
Sounds like a starter motor issue or a starter relay.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby joff_nz » Tue Jan 31, 2017 4:43 pm
duh, thanks man. I'd not been finding anything online but your post prompted me to use 'Starter relay' specifically which has given me some good hits. I'll report back once I've had a further look.
Thanks again
Long time reader
joff_nz
Postby Vertigo » Tue Jan 31, 2017 6:45 pm
If all the dash lights go out when you try to start, its likely a shorted starter motor.
TVIS just kicked in, yo!
Vertigo
Postby sergei » Tue Jan 31, 2017 11:16 pm
probably worn brushes in the starter motor. The way the starter is wired the solenoid will not engage if brushes are worn.
http://www.autoshop101.com/forms/h7.pdf
Postby joff_nz » Thu Feb 02, 2017 5:37 pm
So ah, I removed the starter relay to look at it. Put it back in. Now it's starting Everytime.
Yay cars.
Long time reader
joff_nz
