1994 Hilux Surf timing light reset?
Postby jacobrjett » Fri Aug 11, 2017 4:51 pm
Changed the belt how do you turn the timing light off? Google said to turn reds on hold tripmeter down turn key off and on but didn't work. Cheers
jacobrjett
Re: 1994 Hilux Surf timing light reset?
Postby RS13 » Fri Aug 11, 2017 7:07 pm
Key on to ACC (first position). Hold down trip button and turn key to ON at same time. All lights come on, continue holding trip button until timing belt light goes out. Does that not work?
RS13
Postby jacobrjett » Fri Aug 11, 2017 7:21 pm
Does not work on older models. Cheers
jacobrjett
Postby matt dunn » Fri Aug 11, 2017 11:47 pm
It is possibly old enough where you have to pull the dash out and change the screw location over in the back of the cluster.
Postby jacobrjett » Sat Aug 12, 2017 12:46 am
For 10 seconds??
jacobrjett
Postby jacobrjett » Sat Aug 12, 2017 12:48 am
Sounds likely, it doesn't seem simple. Cheers
jacobrjett
Postby jacobrjett » Sat Aug 12, 2017 12:51 am
Dash pull seems likely thought id check with the know how first. Cheers
jacobrjett
Postby matt dunn » Sat Aug 12, 2017 8:45 pm
jacobrjett wrote:Dash pull seems likely thought id check with the know how first. Cheers
Is the odometer digital display,
or the old wheels that roll around with the numbers on them?
Digital will most likely be push button,
old style will be dash out.
Postby jacobrjett » Sat Aug 12, 2017 11:39 pm
Old style cheers
jacobrjett
Postby Mr Revhead » Sun Aug 13, 2017 8:01 pm
94 Surf, pull the dash cluster out and swap the screw
