toyota progres manual conversion
Stance Boi
- Toyspeed Member
hey Im young and new to the car scene and i was wondering if it was possible to manual swap and toyota progres
Re: toyota progres manual conversion
Purely take a stab here. But I imagine it will cost quite a bit to do and require a fair bit of messing around and fabrication. On top of that it will need to be certified. If you want a manual car of that size, i'd try find something that fits your requirements from factory.
It's not usually worthwhile doing this IMO.
- Dell'Orto
- ** Moderator **
Hardest bit would likely be a pedal box...Mark X may suit? Any JZ bellhousing should bolt up.
Do these have the silly floor mount handbrake?
