1NZ VVTI Idling rough
Post Reply
evil_evo
Post by evil_evo »
Hello All,
I have a Toyota Auris 2006 engine 1NZ Chassis NZE151-1000394 VVTI.
Recently I noticed that engine idling roughly and I can also see that once car is warmed idling between 600-500 RPM ( mostly stays around 600 however it does drop a little maybe 580 and then goes back to 600). I have no engine light but I can see air filer area is vibrating roughly.
So I did the following
I scanned the car using ODB2 scanner - no code found
just to make sure my scanner is using I unplugged the MAF sensor and surely enough scanner picked that up so scanner is working
Car does have an electrical throttle body - I took that a apart and cleaned it ( it wasnt that dirty )
I also cleaned the MAF sensor
I checked for vacuum leak - I did my best looking for any leak but I couldn't see much
I am kinda new to this and I was trying to figure out where is idle control valve, sometime this can be the issue ? OR the Engine Variable Valve Timing (VVT) Solenoid ?
Can someone please let me know where are these components are located ? If anyone has any diagram please let me know. OR Can anyone here help me would might be the issue or what to check next please ?
Thanks in advance.
Re: 1NZ VVTI Idling rough
Post by Dell'Orto »
Did you check the coils and spark plugs?
Contact:
Post by matt dunn »
It may not have one as with e-throttle they can just use that.
Post Reply
