Well I think sit sort of near the top of the scale, a bit of 4 and a bit of 6 but I am no mechanic.
I have rebuilt a cylinder head(on a mini)
I have changed loads of head gaskets.
I have done welding fabrication to make stuff like seat brackets, 5 link rear end, engine/gearbox mounts.
I have put an engine in a car it didnt belong in.
I had a go at an efi wiring loom but I didnt have an accurate diagram and had to get a pro to step in and finish it off.
I havnt ever needed to rebuild an engine.
I have done small amounts of spraying(just one guard).
I have done loads of welding rust repairs(MIG)
I have done stereo installs(I dont do stereo anymore cause they add weight).
I've made a cold airbox, welded up steel intercooler piping.
All machining I have to outsource cause I dont have/afford to buy a lathe or milling machine to do stuff like shorten propshafts and drive shafts and cutting splines and what not etc....
When it comes to cars what can you do / have you done.
- metal_sean_head
- Toyspeed Member
mikethecripple
- Toyspeed Member
i guess i know abit.
-rebuilt 3x 4ages
-rebuild a B16a
-rebuilt numerious motor bike engines from CR125, YZ80, XR200
-rebuilt a Subaru gt leggy gearbox
-stripped down the sequensial twin turbo setup and re installed it. ahh never again.
-rebuild BMW 318is motor
-rebuild a RB30
clutches, brakes, CVs, suspension are no hassle.
all cars have the same principle they are all the same in some sence. its like a jig saw
-rebuilt 3x 4ages
-rebuild a B16a
-rebuild a RB30
AE92 Trueno Sprinter 4AGZE
- jakesae101
- Toyspeed Member
i do a bit of it all i have pretty much rebuilt a escort mechanically brakes motor box ect but now dont do as much carbs and sohc are easy supercharged dohc efi not so much but do my brakes suspension sounds ect
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
car
im just about up to the 5th category on the pole yay :p . have done 2 complete conversions now and helped with others. can do wiring, engine + box swaps, suspension, bodywork, painting etc. started on the mig welder, not the tidiest welds but im still learning
. last cressida i had my p/s lines done and exhaust by other people, prety much everything else I did. thank my lil bro for bringing out the tinkering bogun in me hahaha
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
- h8wrxs
- Toyspeed Member
- Location: travelling to candy mountain with my magical leoplurodon
havnt had a reason/opportunity to rebuild a motor/ gbox yet
ive pulles motors out and put them back in, changed diffs, upgraded brakes and alot of other stuff, i do admit i always ask advice/giudance from mates who know what theyre doing
The four seasons in Australia consist of "$$% it's hot", "Can you believe how $$% hot it is?", "I won't be in today because it is too $$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
