Adjusting AFM trick
Post Reply
www.mods.co.nz
Contact:
Adjusting AFM trick
Post by www.mods.co.nz »
Hi I found a website that explains how to adjust the AFM on my AE92 Levin.
Has anyone else done this mod and what sort of difference in power or response did you get.
It says to move the cog 3-5 places how far is best?
This is the web site www.ae92gts.com/ae92gts_afm_trick.html
MODS Performance Car Parts Limited
Email: andre@mods.co.nz
Web Site: www.mods.co.nz
Mobile: 021 986 322
dohca
Post by dohca »
depending on ur setup
negitive gains can be found.
generally if free power could be found by just winding the afm toyota would have done so.
BUT on that note if you are running headers exhaust and intake you could possibly see some gains by 1,2 clicks.
MrOizo
Toyspeed Legend
Contact:
Post by MrOizo »
i guess if you wanna do it... make sure you have a spare working AFM too..
nothing worse that cocking it up completly and not being able to use your car :o
www.mods.co.nz
Contact:
I am running a 175mm oversize crank pulley, 2.5" exhaust, intake with pod and cold air feed, vr4 front mount intercooler etc...
Mobile: 021 986 322
Contact:
Post by Bazda »
i've done this on my afm, wound back anti clockwise to make it richer, and yea it feels bit more responsive, but i had to do this as i put bluetop cams in and it ran a bit ruff at idle.
it wont hurt to try 2 clicks.
strap-on
Post by strap-on »
yeah, i dont know what your on about dohca.... the reason toyota didnt do it from factory would eb for emmisions... economy etc etc.
it will just up the mixture... like you say too much will have a negative effect, but you may be able to find a sweet spot, may use a little more gas, but slightly more power, but u would need the exhaust and intake done as well
Post Reply
