makin a manifold
4ageturbs
makin a manifold
Post by 4ageturbs »
wats the ideal size tubing and where to get it from to make a manifold for a 4age turbo????
Contact:
Post by Bazda »
steampipe that has a inside diameter same size as your exhaust ports.
steal and tube sells heaps of stuff.
U going to make your self??
Contact:
Re: makin a manifold
Post by matt dunn »
4ageturbs wrote:wats the ideal size tubing and where to get it from to make a manifold for a 4age turbo????
I have a whole lot of steam pipe bends and a custom cut plate that i was going to use to make a manifold.
If you want PM me and we can do a deal.
Matt
4ageturbs
Post by 4ageturbs »
Bazda wrote:steampipe that has a inside diameter same size as your exhaust ports.
Nah mate im gona make a manifold, yeah just starting to gather the bits, do all 4 join into 1 be 4 entering the turbo? and is a mig ok 4 this?
mike simmonds
Post by mike simmonds »
dont join all 4 pipes to 1 just join them to the flange on turbo, mig is sweet, just crank up heat, i would suggest bolting the manifold to somethin b4 welding as it warps the flanges like my one did but would pay to get it machined flat anyway, i have pics of my one that is made from steam pipe and welded with a mig i can send if ur stuck. not a hard job and cost a total of about $150
Grotty
pipe
Post by Grotty »
mike one more pipe you basturd !! ONE MORE BLOODY PIPE !!!!!!!!
Contact:
Post by Bazda »
if u dont know if a mig is ok for this job i wouldnt like to see how it turns out :roll:
mike simmonds
mig is fine, ONE MORE PIPE!!!!!!!!!!!!!!!!!!!!! EEEEEEEH EEEEEEEEEEH, AYEEEEEEEEEEEEEEEEE AYYYYYYYYYE!!!!! i herd about you burnout hayden! i did! i did!
4ageturbs
Post by 4ageturbs »
bazda,
mate some people have some funy ideas 1 guy told me to use a tig but i thaught a mig would be sweet, like you thinking ure the man cause u got a fast car but realy you aint do shit to it, so until you make a manifold urself u have no say
Contact:
Post by Bazda »
4ageturbs wrote:bazda,
mate some people have some funy ideas 1 guy told me to use a tig but i thaught a mig would be sweet, like you thinking ure the man cause u got a fast car but realy you aint do sh*t to it, so until you make a manifold urself u have no say
im the man i know how to do all welds lol.
i'm just saying its not as easy as u think, I bet it will have lots of leaks and prob end up cracking. Seen so many people attempt for the first time and they have all failed.
If they were that easy to make then why charge $500-1500 for a set of manifolds?.
and I dont do shit to my car..... lol sure thing man I leave the car int eh drive way and everything makes itslelf over night.
oh and why is using a tig such a funny idea?? if u want some nice welds and got the cash to get a tig and the experience to use one then tig would be mean.
4ageturbs
Post by 4ageturbs »
Didnt mean using a tig was a funy idea a tig would make a nice clean weld and doesnt give al the stragly shit inside the pipe but ive only got a mig so id rather use that than hire a tig, the good thing bout making 1 urself is that u have al the time in the world
im sure theres alot of people out there who have atemted making 1 and done the mean joby
Contact:
Post by Bazda »
4ageturbs wrote:Didnt mean using a tig was a funy idea a tig would make a nice clean weld and doesnt give al the stragly sh*t inside the pipe but ive only got a mig so id rather use that than hire a tig, the good thing bout making 1 urself is that u have al the time in the world
for a fisrt time round NO one would of done a mean job unless u got the experience under your belt.
Grotty
Post by Grotty »
my burnouts rule simdog, you have to bet my lines in your fwd poc....
use arc welder for manifold !!!!! it'd be mint, REALLY MINT or just use glue. like magic glue. or tig it then mig it. bad man.
ONE MORE PIPE !!!!
mike simmonds
i rekn u gotta start sumwhere! so y not make a manifold! good on u for giving it a go i rekn! i didnt think it was very difficult at all, steam pipe comes in a range of bends to easy to make it go where u want it to. if ur worried about leaks run water thru it and see if it leaks then patch up any hole if any, just crank welder up and do fat welds and it should b fine. NO1 CAN BEAT UR BURNOUTS HAYDEN! NO1!!! burning cock on corona!!
4ageturbs
Post by 4ageturbs »
chers bro u neva no until u have ago unlike that bazda ho*o
just takin the piss mate :lol:
does any1 have any pics of sum manifolds??
Contact:
Post by Bazda »
4ageturbs wrote:chers bro u neva no until u have ago unlike that bazda ho*o
cheers man.
mike simmonds
yea wats ur email i got pics
4ageturbs
Post by 4ageturbs »
Contact:
Post by Bazda »
mike simmonds wrote:i rekn u gotta start sumwhere! so y not make a manifold! good on u for giving it a go i rekn! i didnt think it was very difficult at all, steam pipe comes in a range of bends to easy to make it go where u want it to. if ur worried about leaks run water thru it and see if it leaks then patch up any hole if any, just crank welder up and do fat welds and it should b fine. NO1 CAN BEAT UR BURNOUTS HAYDEN! NO1!!! burning cock on corona!!
if u got leaks, best thing to do is grind back where it leaks and weld over it. Make sure yoru surfaces are clean when u weld or else it will leak.
tatsumaki
Post by tatsumaki »
Also remember a good weld is only as good as your fit-up. Best advice I can give. (Yes, i'm a welder, fabricator).
I'd use TIG if the option is there and purge with argon or nitrogen.
Cheers,
Paul. ;)
Post Reply
