Question for all you 4AGE owners....
How many of you have had the catalytic converters taken off your cars? Has it made much difference in its emmisions? Reason i ask is that a friend of mine has had his taken off, and theres the new emmissions law coming in. Is it still a safe practice?
vvega
- Caveman
- Toyspeed Member
- Contact:
The last WOF I got they gave an emission test for free.
The maximum carbon monoxide is 1.5%
The maximum hydrocarbons (unburnt fuel) is 400 parts per million.
They also measure CO2 and O2 levels for the efficiency of the engine.
My car (ST162 3SGE) got:
CO - 0.01%
CO2 - 15.5%
HC - 132
O2 - 0.09
As you can see it is well within the limit but the unburnt fuel is a little high which i've narrowed down to worn injectors (lower atomisation) hence im getting my injectors reconditioned
It also says on this sheet that quote "Emission testing is not yet mandatory in New Zealand"
CO - 0.01%
CO2 - 15.5%
HC - 132
O2 - 0.09
AW11 Track Toy
Formerly known as 1998
Yes these laws are coming in, and they're not very far away, either. Emissions laws will not be historical, so older cars wont be affected.
Personally, I think it's an EXCELLENT idea. We're one of the only countries that doesnt have emmission laws. Clean green NZ my ass. If you guys had any idea how effective cats are, you'd realise EVERY car should have one. They make such an enormous difference to pollution.
A cars catalytic converter doesnt work effectively until it's up to operating temperature. If started from cold, the average car will produce 95% of it's emmissions in the first minute of a 10 minute journey. Once at operating temperature, a car will only produce a tiny fraction of the emmissions of when it's cold.
ChaosAD wrote:How will the fully worked rally cars etc get warrants?
I cant imagine anything running 300+ degree cams and avgas or a dirty big turbo passing the emission tests.
Cos some competition cars need to have a warrant dont they?
Or will an authority card or motorsport licence get you around this?
Duh, ok, duh, I'll just take my 'fully worked fally car' through the vtnz testing station, aye?
- TotemoAW11
- Toyspeed Member
- Contact:
Dr-X wrote:ChaosAD wrote:How will the fully worked rally cars etc get warrants?
I said RALLY car, not FALLY car. And YES some competition cars DO have to be warranted to participate in certain events!
So shut that mobile sperm bank you call a mouth and think b4 u comment!
If I wanted 2 hear from an arsehole I'd fart!
Have a look at this:
http://www.motorsport.org.nz/Pdf/get_st ... llying.pdf
It lists the minimum requirements for rallying as:
A fully prepared rally car, Registered and with a current WOF, etc
- TotemoAW11
- Toyspeed Member
- Contact:
