How do i remove the oil filter on my s/c aw11 mr2 is thear a trick to it which i dont know?
use to changing the filter on my rotary at it's on top of the motor
Oil filter on a s/c aw11
FAST AND RELIABLE IS NOT CHEAP
FAST AND CHEAP IS NOT RELIABLE
CHEAP AND RELIABLE IS NOT FAST
Monsterbishi
- Toyspeed Member
- Contact:
Re: Oil filter on a s/c aw11
sxymr2 wrote:How do i remove the oil filter on my s/c aw11 mr2 is thear a trick to it which i dont know?
It's just like any other one, just unscrews...
iirc, if you get a genuine toyota oil filter, they are shorter than generic ones, so are easier to fit/remove in the future...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
ok now if the filter is in the same location as the n/a aw11s
which it shud be from memory... its easy...
2 ways... either use a filter wrench on it... or alternatively... hammer a screwdriver thru it and use this to unscrew it...
pretty simple really...
ex 84 AW11
now the proud new owner of a bright red 91 G Ltd SW20!!!!
Monsterbishi
- Toyspeed Member
- Contact:
- kingcorolla
- Toyspeed Member
all A series engines have the filter just below the ex manifold,
always used to burn ma hand doing services
1983 Carina AA63 4age
