Trueno BZG Power
TruenoBZG
Trueno BZG Power
Post by TruenoBZG »
Hi
Have recently scored myself a 1996 Trueno BZ G, the 1600 20v black top 4AGE, 5 speed. I like how the car handles, however it does lack a little power down low compared to my old Celica 2.0l.
Wandering what I could do to improve torque and overall power? I have so far had the following options suggested:
-Spark plugs
-Extractors {the engine does actually have extractors, but not aftermarket}
-2 inch Exhaust
-Air Filter
Anything with the ECU i could change?
Cheers!
Dr-X
Post by Dr-X »
Spark plugs are a maintenance thing, and have affect on performance until you're into serious HP figures (or your old ones are completely r00ted)
AFAIK, stock 20V extractors are pretty decent, and not worth upgrading.
As far as NA engines go, unless you're looking at spending big money, just do the basics - as you say, exhaust and filter to start with. I personally dont believe you'll notice a huge difference, but any engine likes to breath a little better.
I'd be looking at a 2.25" exhaust, k&n panel filter (or similar), and see how you like it, and work from there.
TruenoBZG
Post by TruenoBZG »
Dr-X wrote:AFAIK, stock 20V extractors are pretty decent, and not worth upgrading.
Interesting 8) - cheers for that. Why a 2.25"?? Ive had someone else suggest this as well - Why not just 2"? Does .25" make a difference?
thanks
B1NZ
Post by B1NZ »
keep the revs above 5000rpm :wink: Oh and take off the Trueno badges/stickers and get some levin ones :P
Subaru GF8 Wagon
Subaru GC8 rally car project
Flyboy
Post by Flyboy »
B1NZ wrote:Oh and take off the Trueno badges/stickers and get some levin ones :P
The Trueno badges are stealth... :lol:
TruenoBZG
Post by TruenoBZG »
You know, ever since I took this car home from the yard, ive been seeing the Levin version of it {BZ?} everywhere! The only thing I can see from the outside is the exhaust is smaller - What IS the difference between these two cars?
Contact:
Post by deaf_rattle »
2" is plenty big enough
Dr-X
Post by Dr-X »
Probably, but I'm yet to see any evidence that going bigger reduces power. All evidence I've seen simply says that bigger is better, and the most efficient way of running the engine is right off the headers, if possible.
And yes, I know all the theory, but it doesn't really stack up. At the end of the day, the stock exhaust would probably be fine, after removing major restrictions (eg cat, mufflers, tight bends.)
Contact:
to peak power, there is a point where getting bigger makes no difference.
But torque is affected greatly in an n/a car.
bigger isnt always better, and 2-2.5" is suitable for 2-2.5l.
I ran a 2.5" system on my 2.8 and i noticed a little less low down torque.
but peak power was up 6kws at the wheels
Dr-X
Post by Dr-X »
You realise that if peak power is up, so is torque, right? Sot he simple solution is to keep the revs up.
edit: nm, just realised that doesn't really make much sense if your peak torque is not where near your peak power :oops:
Contact:
deaf_rattle wrote: and i noticed a little less low down torque.
low down torque
flygt4
Post by flygt4 »
you also forget the fact than an over sized or poorly made exhuast sounds shite on a 20v ,i hav heard some shockers b4.depends if u like the 20v tang or not i spose :wink: most of the 2.25 ones ive heard dont actually sound too bad.
out of curiosity , hav many people tried running nos on 20v's before?? i hav seen a few hondas run it with a lot of success , and it actually isnt that costly for the gains you make.
Dr-X
Post by Dr-X »
flygt4 wrote:you also forget the fact than an over sized or poorly made exhuast sounds shite on a 20v
Sure, but he's after performance, not wank.
Post by Lloyd »
TruenoBZG wrote:Why a 2.25"?? Ive had someone else suggest this as well - Why not just 2"? Does .25" make a difference?
Just so you know, that extra 1/4 of an inch (6.3mm) of exhaust pipe diameter will increase the area of the exhaust pipe cross section by 26.5% over the 2 inch pipe.
Zero_Cool
Post by Zero_Cool »
Yea but with NA cars it velocity no volume the faster the exhaust comes out the more it pulls out
TruenoBZG
Post by TruenoBZG »
hehe, exactly. I want more power, preferably not more noise, but i suppose it comes along with it.
HRT - yeh, i see what you mean, but for a 1600? It wouldnt really make a difference would it?
Contact:
Post by Bazda »
The standard exhaust system on a bzg is already bigger than 2"....so upgrading from that would prob be good, my mate took his cat out and he said that improved the torque down low.
what I would do it take out all the resonators/cat and muffler, and fit a nice free flowing muffler on and maybe 1 or 2 19" coby resonators with the built in expansion chambers (giv more back pressure=more torque down low) with 2 1/4" pipe
qik20v
Post by qik20v »
just measured my stock exhaust and its 54mm, thats 2 1/8 inch,
so do you really want to downgrade to a 2"?
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
Dr-X
Post by Dr-X »
A 2" free flowing mandrel bent exhaust will be significantly better than the stock 2 1/8" press bent exhaust. But I would still go bigger. There's no compelling reason not to, imho.
Contact:
how free flowing is that tho?
Post Reply
