sliver top into aw11 mr2
Post Reply
blue-smoke
Post by blue-smoke »
can some one help me , i want to put a sliver top into a aw11 mr2 and i want to know about engine mounts and the whole process in putting it in
CaM
Post by CaM »
should bolt straght in using your old mounts
wiring will be the only "hard" part... rest is childs play
85AW20v
Post by 85AW20v »
YepCaM is right. Water lines go backwards to what you think but you can still use all the blue top bits - just have to rearrange them. You'll need to lengthen the silvertop extractors by about 40mm to clear the starter motor and use the thin plate that goes behind the flywheel, from the blue top. Silvertop flywheel and clutch fit the std gbox and as far as I remember the std mounts work as does the throttle cable if you rearrange the where it comes out to above the crossmember behind the fuel tank rather than underneath it. Wiring is a bit of a nuisance but not too hard if you have wiring diagrams.
Have fun!! Its great fun when you're finished!!
See ya
Simon
85 MR2 20v
Contact:
Post by Mr Revhead »
you will have issues with the starter, if its on the exhaust side. need to mod no 1 runner to clear.
MR2boy
Contact:
Post by MR2boy »
Mr Revhead wrote:you will have issues with the starter, if its on the exhaust side. need to mod no 1 runner to clear.
sometimes, seems to be luck if you need to modify it or not, mine fit without modification so check it first
**** Car here ***
vvega
Post by vvega »
grinding the flange works well
as thats the part that wont clear the starter
or.... use a ae-92 starter....
or use the 20v gearbox front housing and put the starter on the back....
v
blue-smoke
thanks for the info , im going to get my hands on a silver top then do the pistons and cams and shit like that then bolt it on so it might take awile but it will be laceing skids around chch when its done
MR2boy
Contact:
Re: cheers
Post by MR2boy »
blue-smoke wrote:it will be laceing skids around chch when its done
lets hope not, enough idiots doing that down here already
**** Car here ***
Re: cheers
Post by Dell'Orto »
great way of getting rid of another one ;)
blue-smoke
na im just jokeing , safer on a track .
Post Reply
