Headdeck
Post Reply
Guido
Headdeck
Post by Guido »
I just purchased a Pioneer DEH3750MP headunit.
http://www.trademe.co.nz/structure/auct ... d=29401092
I just have had some problems installing it. See the cables in the car and the plugs in the back are different. Some people say I should get a converter plug or something, others say I should get it done proffessionally. How much would i cost proffessionally, how much does a converter plug cost and what does it look like?
Thanks
Toyota... for life
Post by Alex B »
$30 from supercheep for a convertor plug, not being mean but if you dont even know what a convertor plug is maybe you should look at geting a pro to instal it. I think its about $70 :)
AJz
Contact:
Post by AJz »
its about that price, where you live, im sure a fellow toyspeeder will be able to do it for you if you supply sum beverages :P :P :P
takes about 15 - 20 mins if that.
I had vtax :(
Post by Alex B »
yea il do it for $20 if ya in dunners, youl have to supply loom adaptor tho...
Contact:
Post by Bling »
nice head unit btw 8)
z|gen
Post by z|gen »
if it has the loom on the back of the headunit, just cut the plug off inside the car and crimp some bullet connectors on and plug in play like that, there will be 3 main wires - red, yellow and black
red - acc
yellow - constant power
black = earth
and then its just a matter of finding which ones your speakers are, which should be dirt easy.
AE91 SUPERCHARGED COROLLA
Guido
Post by Guido »
Wow thanks for all the replies people :D Youre a lot more helpful then any other forums id ask.
Bad news, however. I just found out the 3 year warranty only counts if it is installed by a pro, and its probably worth spending however much it costs to keep the warranty.
Are there any cheaper places then $70? Sounds a bit steep for a 15min job..
Toyota... for life
Post by Alex B »
$70 is a gestimate just http://www.yellowpages.co.nz price around man
fx'dwagon
Post by fx'dwagon »
15 mins is a f..ing ruff job most installers use solder to connect their wires(most good installers)and take an average 30 mins to do a good job bullet terminals create a connection spot where you can lose power (but not much) and also you can have problems with them if not done properly so ask around and make sure its done with solder or the unniversal pioneer to toyota plugs you are talking about
Post by Alex B »
i remember someone on the forums not so long ago saying soldering was a bad idea :?
fx'dwagon
Post by fx'dwagon »
please explain why???
as it connects two wires together just as if they were new
so if you were to install an alarm you wouldnt solder on the wires
Post by Alex B »
yea i have soldered them, no i wont explane why because as i said someone on the forums said it wasnt a particually good idea, somehting to do with the vibrations from memory.
fx'dwagon
Post by fx'dwagon »
Thats cool :D in my 4 years of many (i cant count them) installing radios i have never have a problem but no worries
Post by Alex B »
i take it you do this for a job? i find conector strips nice n easy to use tho. Specially if ya like me changin headunits every 5 mins...
CozmoNz
Contact:
Post by CozmoNz »
every speaker, radio, headunit and whatever else electrical (inc foggies and larger current draw-ers) ive ALWAYS used the strip and crimp method, never ever soldering.
and ive never encounted a problem.
soldering just makes it harder, messier, and something else to go wrong (like me burning myself)
Rayne For President!
fx'dwagon
Post by fx'dwagon »
no offence but you must not be very good with an iron then,, dont get pissed im asking a question
CozmoNz
Contact:
Post by CozmoNz »
Yeh, me not using them and all.
the answer?
well mine would be, its easier to remove speakers from a car you may be selling, same with headunit too, and well, anything electrical you may want to remove again.
remind me again, why arnt ecu's solded into the wiring?
why do they make removeable plugs?
same reason. so things are REMOVEABLE.
fx'dwagon
Post by fx'dwagon »
im only talking about wiring up headunits into their loom i dont solder in speakers thats just silly
CozmoNz
Contact:
Post by CozmoNz »
Well, you seem to be the annoying person, that causes me to cut all the wires when im changing my headunit!
id rather just pull the plugs out, crimp new plugs to the headunit, and plug and go!
fx'dwagon
Post by fx'dwagon »
nah not me most of the cars i do proberly dont drive down there to get another radio put in :P
Post Reply
