Now, I am looking for a 4AGZE AFM ECU or another knock sensor.
PS: If anybody can shed more light on this problem, I would greatly appreciate it.
Dimon wrote:Hi Guys, I am having a weird problem ... it all started with knock sensor producing an error intermittently, I have then cable tied the wire going to the sensor and the problem seemed to go away for a while ... when it stated happening again, I decided to change the sensor and it was fixed again for less then a day .... and now no matter what sensor i plug in, the error pops up as soon as I exceed 3000 rpm ... regardless if its under load or not. Hence I concluded that the ECU must have been toasted...
