hi ppl im in the middle of repainting a ke70 sedan
how do you take the rear glass out and can you buy new rubbers for it and the crhome bits on the outside that hold it in
and does a wagon front windscreen fit in a sedan
ke70 sedan project
- KE25-KP30
- Toyspeed Member
Hey, I just used about 3 screw-drivers and slowly went around kinda moving them to pull the window out. I managed to put a dent from pulling down on the screw-driver too hard tho, i s'pose if you're careful you'd be sweet. Watch out if there's any black gum sealer stuff, and use plastic gloves if there is. I scrubbed my hands for about 1/2 an hour before working out that meths gets it off
Good Luck!
Good Luck!
Re: ke70 sedan project
mazmad wrote:and can you buy new rubbers for it and the crhome bits on the outside that hold it in
You can buy new rubber, from toyota its $$% dear, I got mine from aussie from Scotts Old auto rubber its quite cheap. And the chrome KE70's use the bit thick metal type chrome aye? Mine is a thin strip that slips into a channel in the rubber, I found that stuff new too.
You can get them over here, dunno of the name. I just rang up Scotts old auto rubber, theyve got a website. And Placed my order, paid by credit card and they sent them over. Good people to deal with, they have every rubber imaginable. I got all new rubber for 4 doors, both windscreens, the velvet sliders for the window and it was about $800NZ landed.
scotts2hot
- Toyspeed Member
