What would a 4agze with a SC14 develop ?
How many people have done this ?
Is there a proven process for this ?
SC14 on 4agze
SC14 on 4agze
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
06 RS4 Avant
- soopachargen
- Toyspeed Member
- Contact:
I have an sc14 on my rolla... what sorta stuff do you want to know? It's yet to see a dyno but goes a lot better than the sc12 and makes very strong power till it hits the limiter hard. Add me to msn if you want.
When in doubt, down and out.
soopachargen wrote:I have an sc14 on my rolla... what sorta stuff do you want to know? It's yet to see a dyno but goes a lot better than the sc12 and makes very strong power till it hits the limiter hard. Add me to msn if you want.
When will you put it on the dyno ? I'll be VERY interested to see that chart. How many hours to make the mod ? Did you essentually bolt off bolt on or was there more too it ?
06 RS4 Avant
06 RS4 Avant
- bluemaumau
- Toyspeed Member
beeker wrote:soopachargen wrote:I have an sc14 on my rolla... what sorta stuff do you want to know? It's yet to see a dyno but goes a lot better than the sc12 and makes very strong power till it hits the limiter hard. Add me to msn if you want.
ive beem told you need to move your mounts forward as the sc14 is larger. however im not sure if this is engine or s/c mounts
Where the $$% is that oil leak coming from /club
- soopachargen
- Toyspeed Member
- Contact:
The sc14 fits on the lower mount with a washer as a spacer. I have an sc12 pulley modified to fit on the sc14 shaft with a spacer to put the pulley inline with the rest of the pulleys. A top mount has to be made up to to hold the blower in place because it sits out further than an sc12 due to its size. Piping has to be modified. It's not straight bolt on, but with the charger mounted at the bottom you could mock up your pipes and top bracket. You have your gze in an '85 or '86 aye?? That should give you some more room to work with. I can fit my charger down into my ae91's engine bay with the motor in place but fabrication would be hard. Have a talk to bazda coz he and Fred put my kit together for freds car.
thats me
o wat the heck i want to feel as cool as bazda so here goes
thats me.....
but ask bazda lol he knows what hes on about, its well worth the effort never had it completely setup on my car but it is nuts compared to sc12 and has potential of 18psi so ive heard
thats me.....
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Bazda wrote:thats me
Bazda, do you have a SC14 setup yourself ? I would love to look at someones to get a overview of what work is required and also what the result is like. Its either this or a turbo setup. If the SC14 is a quick and dirty way of getting some extra hp and maintaining the same throttle response compared with the cost of doing a 'proper' turbo setup, then i may consider it.
I want throttle response and minimal lag, as much as an HP increase. Extended WOT reliability is also key. I wont do it next late late this year, but just figuring out the plan.
06 RS4 Avant
06 RS4 Avant
beeker wrote:Bazda wrote:thats me
no i dont have a sc14, i put a sc14 onto freds old car but then fred sold it to soopachargen.
