Sandblasting.
Post Reply
Elmo
Sandblasting.
Post by Elmo »
I now have the facilaties to do sand blasting.
If anyone wants anything done let me know.
Small price of $5 (pretty much flat rate for a handfull of small bits)
Larger items by negotiation (as I have to take set up to work and use a bigger compressor)
I call small items things to about the size an alternator.
I can fit most suspension parts on my 'tank' but as I said, I need to do larger items at work.
Ken
Note, all care, no responsibilty.
Contact:
Post by Bling »
sounds good!
will have to send ya a PM sometime as I may need some parts doing,
as below, got starlet, and could be keen as i'm sure thats a good way to prep parts to be painted? correct?
Elmo
Post by Elmo »
Its pretty much THE best way to prep for paint as it gets rid of everything (oils etc do need to be cleaned off with a solvent, as you'd expect)
RS13
Post by RS13 »
Would a cam cover be too big?
Contact:
Post by Bling »
i'll put together a box of stuff then, then we can talk $$ 8)
Elmo
Post by Elmo »
Cam cover would be fine.
Ken
Virtual Genocide
Post by Virtual Genocide »
How about a set of 14" rims????
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Elmo
Post by Elmo »
I dont see why I cant do rims. Would be a little more costly due to time involved tho. And Id have to do at work. But yeah, I dont see why not.
Post Reply
