Hey,
Have done searches on locking diffs on here, and found a bit of information, but can someone give me a bit more please.
Im starting a beach offroader project, where I plan on using a 1L FWD Toyota engine. Problem is the FWD diff. I originally wanted to use a motorcycle engine, but I havent found one at a good price (thats another question, if someone has a 400cc to a 600cc good running engine for sale, pm me asap plz).
So it looks like Im going to be using a 1L Toyota Vitz engine I have sourced.
I want to lock up the diff, so I can just run a single shaft out to a single axle. This is only going to be used on the beach.
Is it very difficult to get at the diff, and weld up the spider gears? Do you just jam bits of metal in them, then weld them up (after cleaning it fully to get rid of fire hazard oil etc). I have some welding experience, no tickets or anything, but I am able to weld no problem (MIG welding).
If anyone has a sample pic of a FWD engine with its spider gears visible, so I can see what I will be in for, I would really appriciate it.
I havent got the engine yet, hence me still being keen on a 400cc to 600cc motorcycle engine.
Any info would be really appriciated.
Thanks
WanaGo
Locking FWD Diff - tips
- WanaGo
- Toyspeed Member
'98 Toyota Caldina GT-T
'97 Kawasaki ZX9R Motorcycle (900cc sportsbike 142HP)
Bike Pics: www.taktik.co.nz/bike/mybike/
you need to take the gearbox apart to get at the diff centre, and the diff is usually the first thing in, LAST thing out. Its not hard to pull apart tho, if you're mechanically inclined.
welding it up, make it nice and clean, (washbath, petrol etc) then weld the spider gears to the side gears, and the spider gears to the pin, and the side gears to the carrier, then box the gears by welding a chunk of 10mm plate in the space between the side and spider gears. just have a look and weld it up for life!
there must be some 323 owners down south that can show you what they look likeWanaGo wrote:If anyone has a sample pic of a FWD engine with its spider gears visible, so I can see what I will be in for, I would really appriciate it.
except in a 323, where they often jump shipedwagon wrote: the diff is usually the first thing in, LAST thing out.
- MetalupYoAss
- Toyspeed Member
- Mr. Mainstream
- Toyspeed Member
- Contact:
fangsport wrote:there must be some 323 owners down south that can show you what they look likeWanaGo wrote:If anyone has a sample pic of a FWD engine with its spider gears visible, so I can see what I will be in for, I would really appriciate it.
he's dead right, just look in my photo bucket
75 MK2 Ford Escort L 2.1L
Various Others
Various Others
