LSD Gearbox?
z0ton
LSD Gearbox?
Post by z0ton »
Did any of the ae101 1991 Silvertop levins come with an lsd box?
Emperor
Contact:
Post by Emperor »
GTZ - Yes
GT - No
GT Apex - No
(I think)
AceSniper
Post by AceSniper »
nop not factory
z0ton
Post by z0ton »
How important is it to have an lsd gearbox with a fwd turbo 20v. Ive got a 1994 liftback corolla with a 4afe in it. I have a silvertop gearbox but will the axles and that gearbox be strong enough?
flygt4
Post by flygt4 »
probly not. save yourself money in the long run and buy a gtz gearbox and shafts.
then if you're making any decent power invest in an aftermarket mechanical lsd , the factory viscous ones arent too bad , but most are tired and people ask stupid money for them. a decent lsd in a must if you want to be able to go anywhere, rather than spin a wheel everytime u touch boost. .
z0ton
Post by z0ton »
What about this?
http://www.trademe.co.nz/Browse/Listing ... d=64234640
I have no idea how much just an lsd box is worth, is that quite expensive?
demis
Post by demis »
i think they were Always a factory option on the 4age powered cars
i have herd of a few around that defentally have lsd's
then there are the c56 gear boxes like mine with an lsd, i couldent tell you if it was factory fitted or not
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
phat5k
Post by phat5k »
You can get the heavy duty axles on non-LSD boxs, its a bit of mix and match, and if you want to know if its factory LSD look at the trans/axle code C5* -**B is LSD A is open
i like desprung :) it makes titties bounce!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1362
demis
Post by demis »
Contact:
Post by Mr Revhead »
c= lsd. not b.
c56 + s/s = lsd
have never seen an ae101 non s/c with lsd. or find any evidence of lsd on the epc.
Dirtbag
Post by Dirtbag »
Mr Revhead wrote:c= lsd. not b.
c56 + s/s = lsd
Is that meant to mean superstrut, or a mistake meant to mean supercharged?
AE101 GT-APEX Superstrut
My profile!
Contact:
no, thats superstrut.
or, put another way which may be more accurate, ae111 with s/s = lsd.
ae101 gtz = lsd.
slighty_sykotic
Post by slighty_sykotic »
Thats always is it Mr revhead? All s/s ae111 had an lsd?
Hmmmmmmmmmmmmmm
--Sykotic
Contact:
yep that appears to be the way it is
AceSniper
Post by AceSniper »
hmm bzg's = c56 s/s without lsd... so ...??
Iv seen a torsen ae111 style lsd in a facelift ae101 c56
aw11's some had TRD clutch lsd's (c series)... was going to slap one into my box but now gota Kaaz
Contact:
bzg + s/s = lsd
ae111 lsd = viscous
AceSniper
Post by AceSniper »
hmm revhead can you show images of this? as iv never seen a viscous in a 4age box only a starlet gt c series which has a changed case to fit the diff, most if not all ae111 lsd's are torsen... (BZ-R ones anyway)
Contact:
have you had one apart and looked?
got pics?
AceSniper
Post by AceSniper »
pmd :D
Dirtbag
Post by Dirtbag »
I know someone with a bz-g S/S, looking to sell his car I think, I should swap the gearboxes (OH THEY ARE THE SAME MATE!) :P
My profile!
Post Reply
