Spark plug soaking in oil?
Post Reply
Banga69
Contact:
Post by Banga69 »
Hey guys whats the cause of this? too much oil in the sump? tappets?
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Post by Lloyd »
Depending on engine... the rocker cover gasket/seals that run around the spark plug holes are likely to be the cause
Ae92typeX
Post by Ae92typeX »
worn out rings or valve seals two possibilities...if you are talking about oil on the spark side of the plugs.
Contact:
Post by Rick »
HRT wrote:Depending on engine... the rocker cover gasket/seals that run around the spark plug holes are likely to be the cause
Maybe, if there is oil on the spark plug lead side, but it sound like the combustion chamber side, which can be caused by oil leaking passed worn valve guides or pistion rings.
Post by Lloyd »
Haha, didn't even think of that. Maybe its because I was working on something with the top of the plugs soaking in oil the other day
Post Reply
