It's On Again! HKS / Greddy / Apexi / JUN / SARD Groupbuy
Fortyone.co.nz
Contact:
Post by Fortyone.co.nz »
Fortyone Automotive
Mac - http://www.fortyone.co.nz
mac@fortyone.co.nz
64 4 566 1007
Image Apexi
Apexi Power Intake Kits for Turbo from $225
Apexi Power Intake Kits for N/A from $225
Apexi Replacement Filters - $95
Apexi AVC-R - $845
Apexi RSM - $325
Apexi AFC Neo - $595
Apexi Auto Timer - $140
Image HKS
HKS SSQ Blow Off Valve - Simple. $450.
Camshafts - $635 each !
Valve Springs - $295
Cam Pulleys - $495 / set!
Timing Belt - $285 each!
Forged Piston Kit - from $1995
Stopper Type Head Gasket - From $380 to $480
Connecting Rods - 3SGTE - $1645, 2JZ - $3495
Blow Off Valve Type II - $560 (Told this was a great price!)
Standard Wastegate - $1100
EVC V - $815
EVC Black - $995
EVC EZII - $765
Comparison
Full Auto Turbo Timer Type 0 - $145
Full Auto Turbo Timer Type 2 - $225
HKS Air Fuel Ratio Regulator - $225
Fuel Cut Defender - $225
Image Trust / Greddy
Blow Off Valve - Type R - $395, Type RS - $295
Forged Pistons - 1JZ / 2JZ - $2195
Connecting Rods - 1JZ / 2JZ - $3675
Cam Sprocket - $195 each
Gaskets - various thicknesses - 7M, 1JZ, 2JZ - from $245
Airinx Intake Kit - $245
Trust 550cc or 720cc Injectors - $840
Trust Shift Knob - $70
Breather Tank - $170
Oil Catch Tank - $160
Oil Caps! - $95
Racing Gloves - $120
Profec e-01 - $905
Profec B - $525
Full Auto Turbo Timer - $135
60mm Meters - from $350
Trust / Greddy Breather Tank - $195
Image SARD
R2D2 Blow Off Valve - Comes with any fittings needed - $365
Racing Blow Off Valve - $495
P-Box - $1675
P-Link - $475
P-Analyser - $2855
Analyse Racing ECU - from $1595
Face Boost Controller - $745
Type J Wastegate - $1495
Type RC II Wastegate - $1255
Type C II Wastegate - $895 (Wastegate Springs from $55)
Thermostat - $110 (68 degrees opening)
Radiator Cap - $55 (1.3kg)
Radiator Hose Set - from $290
Breather Tank (radiator) - $295
Oil Catch Can - $185
Fuel Pressure Regulator 8mm - $195
Fuel Regulator Setting Meter - $145
Fuel Delivery Pipe - $365
Brake Pads - Type M (200-1000 deg) - from $355 / pair
Brake Pads - Type C (100-800 deg) - from $295
Image JUN
JUN Piston Kit - from $2095
JUN Con Rods - from $1995
JUN Camshafts - from $995 / pair
Cam Kits available also - includes retainers and valve springs!
JUN Valve Springs - from $335
JUN Sports Computer - from $1295
JUN Retailers - from $595
JUN Cam Sprockets - $from $245
Image Tomei
Piston Kit - from $1780
Poncam Cam Shafts -from $1255 / pair
Poncam Camshafts + Pulleys - from $1655
Poncam Camshafts + ECU - from $2095
Procam Camshafts - from $1215
Procam Camshafts + Pulleys - from $1615
Valve Springs - from $395
Gasket - from $435
Image Blitz
DD Blow Off Valve - comes with adapter pipe if needed! - $520
Wastegates from $1120
Carbon Suction Kit - super cool! - $1650
Blitz Oil Filter - $39
SBC i-Color - $1275
SBC i-DCIII - $875
DUAL-SBC Spec R - $715
DUAL-SBC Spec S - $495
For specific information you should see the manufacturers site:
JUN - http://www.junauto.co.jp
Tomei - http://www.tomei-p.co.jp/
Blitz - http://www.blitz.co.jp/
Sard - http://www.sard.co.jp/product/index.html
Trust / Greddy - http://www.trust-power.com/
HKS - http://www.hks-power.co.jp/
Apexi - http://www.apexera.co.jp/carlife/Apexi.html
As always we accept bank deposit, cash, and credit card online - Visa and Mastercard. Full GST receipts are always issued with every purchase for your reference. If there are any questions or mistakes, let me know!
Last edited by Fortyone.co.nz on Wed Oct 24, 2007 10:02 am, edited 2 times in total.
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Contact:
Post by Boosted_162 »
With the RSM, are you able to get them in black instead of the usual silver?
Fortyone.co.nz
Contact:
Boosted_162 wrote:With the RSM, are you able to get them in black instead of the usual silver?
That'd be the D1 limited edition. No longer available!
Contact:
Damn. Theres a few on trademe, but they are more expensive. I dont really think my car would suit a silver one tho :?. Do you know if the RSM has a maintenence alarm? I notice thats one handy feature that the SARD attack meter has over this.. Can you get the SARD attack meter?
Fortyone.co.nz
Contact:
Boosted_162 wrote:Damn. Theres a few on Trademe, but they are more expensive. I don't really think my car would suit a silver one tho :?. Do you know if the RSM has a maintenance alarm? I notice thats one handy feature that the SARD attack meter has over this.. Can you get the SARD attack meter?
SARD Attack meter - of course! $345. I can't confirm re: RSM
LEV_101
Post by LEV_101 »
hi, you can get altezza 3sge engine damper ?
Contact:
Post by deaf_rattle »
to get greddy type r bov or not to? that is the question
Fortyone.co.nz
Contact:
LEV_101 wrote:hi, you can get altezza 3sge engine damper ?
Yep $315 from C-One.co.jp
Matt - Yes!
Ard Righ
Post by Ard Righ »
Any bodykits for Altezzas you can get ? :)
Silent Knight
Contact:
Post by Silent Knight »
How big is the Trust oil catch tank?
Mr.Phreak
Contact:
Post by Mr.Phreak »
Greddy have a transmission cooler??
Fortyone.co.nz
Contact:
Ard Righ wrote:Any bodykits for Altezzas you can get ? :)
C-West, TRD, C-One amongst others. Wald etc =]
Silent Knight wrote:How big is the Trust oil catch tank?
Roughly 1L.
Mr.Phreak wrote:Greddy have a transmission cooler??
Yes - ATF cooler (auto tranmission fluid cooler). Which car?
Silent Knight
Contact:
It's for a JZZ30 Soarer.
I had a look earlier today on their site and couldn't specifically see anything for an AT Cooler.
Do you have a link to it perhaps?
Thanks!
Fortyone.co.nz
Contact:
Silent Knight wrote:It's for a JZZ30 Soarer.
Thanks!
http://www.trust-power.com/spec_swf/04c ... erKits.swf
$595
Silent Knight
Contact:
Dang... that's a bit rough.:|
Sign me up for that Oil Catch Can though!!
Standard wait times again?
Fortyone.co.nz
Contact:
Roger! PM'd!
Silent Knight
Contact:
Can you get the OMORi DIN meter panel?
It's a plate you can screw into a single DIN in your console that holds 3x 52mm Guages.
Silent Knight
Contact:
Fortyone.co.nz
Contact:
Silent Knight wrote:Can you get the OMORi DIN meter panel?
Get - most likely but I am not at all familiar with it. Link?
Silent Knight
Contact:
http://www.omorimeter.co.jp/english/english.html
Click on Parts and you'll see them.
Post Reply
