I'd like to bang a V8 in the street car, mostly used for cruising and will be fitted out with a towbar for pulling the racecar to the track and back eventually...
I'd think 1UZ would be the best option as cheap, reliable and I *believe* a relatively bolt in option for a MKIII supra chassis...
But my concerns are being only a 4.0l that possibly lacking in torque and HP compared to the 350chev... also extra cost of wiring etc to install vs the dirty old carbie setup and plentiful availability of aftermarket bits n bobs for the 350...
Planning to run pretty much stock with exhaust and cold air intake...
Any ideas on stock hp/torque figures for these engines?
Has anyone personally installed a 1UZ into anything else and knows what sort of issues I might run into putting it in and getting it up and running?
Cheers!
