Overboost in sw20
Overboost in sw20
I have overboost problems in my sw20 (yay). The previous owners installed a turbosmart bleedtap style boost controller but this is very limited and makes it hard to know exactly where you are in terms of boost levels
My question is, can i fix this problem by buying an electronic boost controller with a good reputation...or is it a bit more involved than that?
1988 r31 TI Skyline.
hard to tell aye, has he could have left the factory one in aswell. That doesnt always end well. usually you find the cut out real quick
All manual types dont have any easy way of setting a correct level of boost. You just have to play around. My gt4 i previously had did not like having a bleed tap on it. Would sometimes cut out on a cold night from spiking too high.
Electronic ones need to have quite a bit spent on them. HKS and Profec B boost controllers seem to be the best bet. Afaik though, your still setting a gain level not "dialing in" the boost you want. Feel free to correct me if im wrong.
What boost is it running and what does it spike to ??
if its an early mr2 they cut out about 14-15psi from memory
I had vtax
- Toyspeed Member
- Contact:
Well the thing is a dont know what boost it is running as i've only got the standard boost gauge to look at. The previous owner told me boost cut was at 16 (its a '92). There is a boost spike thats annoying me too, as at times I have next to nothing from 5500-7000.
I'm not racing it or anything, but i'd like to think I have a smooth turbo power band all the way through the revs.
This is my first turbo car so its hard to know what to look for.
CT26 turbos (on the Gen1 and Gen2 SW20's) top out at around 5500rpm. Running more boost isn't going to change this unfortunately.
I've got a turbosmart gated bleed valve - might be the same as yours, with a ratcheted adjustment. Its set to 15 PSI (good for 160rwkw) and doesn't spike noticeably. Dialing it in is pretty much a matter of winding it open incrementally until you get to the boost level you want, very unscientific but it worked for me. As mentioned above it would pay to check that the valve has been installed properly , if the factory boost control (TVSV) is still connected you will get unpredictable results...
To start with though I'd recommend you get an aftermarket boost gauge of some sort - they aren't expensive and easy enough to fit. The factory gauge is a bit useless really.
Also - i reckon an EBC is a waste of money on a gen1/2 sw20. The main reason people buy these cars is bang for buck, you could easily spend a 1/4 of the car's value on an EBC. Keep the bleed valve!
HTH
HTH
The problem with socialism is that eventually you run out of other people's money. -Margaret Thatcher
I have a Turbosmart turn knob thingee, their cheapest boost valve, no complain at all, boost fine no spike holds steady. So I doubt it's the actual product.
But then again I don't have the CT26.
When I had the CT26 I also had a homemade bleed valve, no matter how much i dail the boost will drop after 5000rpm, but it does drop in proportion to how much you dial.
Get a boost gauge to start with.
Disable the T/VSV. Theres two pipes that come out of the actuator on the turbo. One will have the bleed valve on it, the other one will head south somewhere that you can't see. Cut that pipe and plug it up with a bolt and cable tie. Problem should be solved.
If you want more boost than the boost cut will give, find the boost pressure sensor on the drivers side rear of the engine bay. It will have an electrical connector on the passenger side, and a hose going into the base. Pull the hose out of the base and plug that up as well. No more boost cut.
- touge rolla
- Toyspeed Member
Wow, thanks guys. Its good to know the drop off at 5500 is normal
I was a bit worried there for a second
i really dont see the point in multi step boost controllers
True, youre only running full boost for a short time so the fuel consumption theory is out, and really you only want to run as much boost as you can reliably.
I wouldnt feel comfortable running my CT20b anywhere over 15PSI on the stock engine with higher kms.
Heylin
Heylin wrote:i really dont see the point in multi step boost controllers
And thats what i am going for, reliability. Last thing I want is to join the 3S blown engine club
- Dell'Orto
- ** Moderator **
23psi is ok in short bursts
- touge rolla
- Toyspeed Member
I suffer from an inability to not floor it
so to save fuel it is good to be able to drive around on 6-7psi maximum
plus i don't want or need 1 bar all the time, so like to drive around on just standard boost and only turn it up when i feel the need. (e.g overtaking or letting a gtst driver know they aren't THAT fast
Everyones different i guess, and i feel the need to play with my boost setting whilst driving
