toyota surf sunroofs
Post Reply
MrBeef
Post by MrBeef »
Hi there, im wonder - roughly how much it would cost the replace the galss in the sunroof..
or if/what models sunroofs are interchangeable?
cheers..
also when you go for a WoF, they actually check the sunroof? cos mine is cracked and pretty fragile. it is actually a requirement to have it sound?
Any last words?
Box, toaster, Aluminum, Maple syrup...no I take that back..im'a hold onto that one.
My beast!
andyztouring
Post by andyztouring »
Best to ring the wreckers for a price on a replacement glass,to changeover to glass is reasonably straightforward,undo the plastic side covers on the glass,remove 4(? I think) bolts remove glass,changeover,refit bolts,adjust glass to fit flush with the roof,refit plastic panels.
barryogen
2ZZ Guru in training
Contact:
Re: toyota surf sunroofs
Post by barryogen »
MrBeef wrote:also when you go for a WoF, they actually check the sunroof? cos mine is cracked and pretty fragile. it is actually a requirement to have it sound?
I don't know if they check it or not, but probably best to get it fixed as I'd imagine that like the windscreen they are a structural item these days.
Ae92typeX
Post by Ae92typeX »
swap it for a sheet of ply...lol, Ive seen it done!
Post Reply
