knocking when realeasing clutch
Post Reply
TRD_ZERO
Post by TRD_ZERO »
When i release the clutch slightly fast i get this knocking noise like im dumpming the clutch. Anyone know what this could be?
allsecretlove777
Post by allsecretlove777 »
Is it a hydrolyic clutch or or cable clutch? Cause mine is the cable clutch and it makes a noise from the spring (i think) which pulls the pedal back after releasing the cutch. I dunno,, is it from inside the cabin or from the gearbox?
al_feinted
Contact:
Post by al_feinted »
possibly broken engine mount?
Project cars: 83 corona tt142, 83 corona mark2 gx61, 82 avante chaser gx61.
www.toycrazy.net
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1408
TRD_ZERO
Post by TRD_ZERO »
OK the front gearbox mount is torn and the rear one doesnt have the bolt through it so its just sitting there not bolted up. Would the mount not being connected make this noise? I just couldnt get the main bolt back in it was such a pain. Its a hydraulic clutch. Would there be any other things that would cause this noise?
Zak
Post by Zak »
Both of them would make the sound, fix them first then look for other problems.
flygt4
Post by flygt4 »
sounds like your problem. needs rectifying before you try fix anything else.
when you press the clutch you transfer weight around on the engine and gearbox.you usually end up rocking it between the mounts and the knocking you hear is metal hitting metal.
one time i snapped an engine mount and what alerted me was a knock when i clutched in to change gear but only at certain speeds.
Dirtbag
Post by Dirtbag »
I've had the same problem, got all the mounts replaced and it still happens, are there any other causes for it? get an unusual clunking sound, and i feel the engine shift in the mounts.
AE101 GT-APEX Superstrut
My profile!
Zak
Post by Zak »
Genuine mounts or aftermarket?
Also what car?
Dirtbag
Post by Dirtbag »
TGP from revvy
ae101 gt-apex, superstrut, completely stock
My profile!
Zak
Post by Zak »
Ok, I'd be looking for play in suspension, drive shafts, wheel bearings and stuff, if thats ok, then maybe the damper in your clutch plate is worn and has play.
All though all most every manual corolla I've driven, and thats alot now, has made bit of a noise from the mounts even with fairly new ones. I think it's just a poor design.
78ke30
Post by 78ke30 »
I have the same problem in a ae111 bzr, but when you release the clutch slow its fine. it also needs the clutch replaced (slipping), have the parts (tgp) will let you guys know once it has been replaced if this solves this.
Previously owned: 1980 1275 gt mini clubman, 1979 mini clubman, 1980 ford escort, 1978 toyota corolla ke30
Current AE111 levin BZR
Bumpy
Post by Bumpy »
Could it be the shaft, that the release bearing slides along, has worn un-evenly?
haydo
Post by haydo »
I have this same problem too. Where's the best place to start looking for broken mounts?
Contact:
Post by Mr Revhead »
you could try looking at the mounts.....
TRD_ZERO
Post by TRD_ZERO »
Thought id give a quick update. I put the main bolt back into the rear mount and it solved the problem car feels alot better too.
Bumpy
Post by Bumpy »
TRD_ZERO wrote:Thought id give a quick update. I put the main bolt back into the rear mount and it solved the problem car feels alot better too.
hehe
78ke30
Post by 78ke30 »
78ke30 wrote:I have the same problem in a ae111 bzr, but when you release the clutch slow its fine. it also needs the clutch replaced (slipping), have the parts (tgp) will let you guys know once it has been replaced if this solves this.
Have had the clutch replaced , but car still has problem. Will look into engine mount.
Mr Revhead wrote:you could try looking at the mounts.....
How much for a set of engine mounts from Toyota (TGP & TRD)
Post Reply
