Hi Guys.
I've got a Ae111 levin bzg with a 5 speed manual.
In winter the gearbox can be shocking at getting into gear when cold.
When the car has sat over night (in garage, worse if outside) or hasn't been used for a day or two, it can be extremely hard at getting into 1st gear after reversing out of the garage. 1st - 4th can all be hard. Sometimes it will slot into 4th then go into 1st more easily. After getting it in its not to bad.
Had the clutch, pressure plate and gearbox oil all done about a year and half ago as I was having similar problems (reverse crunching). The fingers on the pressure plate were very worn so it was like the clutch wasn't fully engaging.
Any ideas on what I should do now? Change the gearbox oil again?
Fussy cold gearbox
- rollaholic
- Toyspeed Member
you can usually adjust the clutch master rod length, at the top of the clutch pedal. not always though, couldnt say for your car.
if the clutch engages as soon as you begin to lift off the clutch, then its possible you are not getting complete dis-engagement, which is obviously going to make shifting difficult.
This still hasn't improved.
One thing I have noticed though. Start the car, all gears ok, can get into everything reasonably easily.
Reverse out of the garage. Very hard to get any forward gears.
It seems like if I reverse when the engine is cold, all other gears are no good. Once I am in first and drive, I can shift to everything ok.
Going to get a mate of mine who works as a mechanic for Toyota to have a look next week.
- RedMist
- Old Skool User!
- Contact:
astrae wrote:This still hasn't improved.
I'm not much of a gearbox expert. However if its a splash type lube system (which I suspect it is) it might be easier to shift while dry. IE once you start moving you splash a stick oil on the synchros which in turn may cause them to slightly bind. I'd be looking at a lighter weight oil before I cracked the gearbox. Especially as it shifts better warm.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
- 79rolla
- Toyspeed Member
if you were having problems befour and changing oil fixed it perhaps give it a oil change again??
see how bad the oil is when it comes out??
and if you have problems after reversing out of the shed then just back it in
problem solved
past: AE82 FXGT
past: AE82 FXGT
