st190 - 191 dizzys compatible ?
Post Reply
Maggs
Post by Maggs »
I just bought and installed a dizzy from a st190 for a corona st191 as the wrecker said it would work. Car started for half a second ,now wont start at all. starter now turns over very fast and high pitched. Rotor moves. Obviously the dizzy or could something else be wrong ?
Post by strx7 »
an ST190 has a 4SFE a ST191 has a 3SFE, larger engine, hence different numbers. However, there is 4 different dizzy's in those vehicles that we have struck, 2 different external coil type dizzys and 2 different internal coil dizzys, the difference is in the number of wires in the plug. If the number of wires in the plug it does the same job.
Maggs
Post by Maggs »
So you cant get a st190 3sfe ? Would you know if the distributors look identical ? Hope i havn't f*cked my engine
Rob
Post by Rob »
Put the toyota part number up here boss and I'll have a look at work.
Where did you buy it?
Also what colour the sticker is which the part number is on.
1990 ST185H - project
1996 VS Acclaim wagon
Crimson Tears
Post by Crimson Tears »
Have you checked to see that it hasn't jumped a tooth on the timing belt?
Post Reply
