Quick Question Ae111 BZR Head Lights
Post Reply
bs
Post by bs »
When you have the high beams on (facelift headlights (two bulbs)), are both the high and low on? Or just the high beam?
Also does anyone knwo the numbers for the bulbs, as I can't find any markings on them.
Stott69
Post by Stott69 »
just walked back out to car and yes low beam is the out side bulb (beside the indicator) and stays on when high beam comes on. im off to bed so can't help with numbers
Image jzs147 Aristo money pit
2LTR Rona
Post by 2LTR Rona »
they share the same bulbs as an AE101 yes? pretty sure they do, rectangular metal end to them with one blue wire coming off it?
If its that then I could probably spot it on the Hella site and show ya which one
2002 Altezza, 1974 KE25
jetshin
Post by jetshin »
when you wire facelift lights into a prefacelift car the low beams turn off when you switch the highbeams on.
here's a link to get around it.
http://s15.zetaboards.com/AE111_Forum/topic/6535468/1/#new
NILPSI
Post by NILPSI »
As far as im aware the facelift AE111 lights have different bulbs to the AE101, AE111 have the HB3 and HB4 bulbs in them where the AE101 have H1 and H3 bulbs
Pull one out it should have numbers on it
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
bs
Post by bs »
Thought they did. And yes putting them in pre facelift, and turn off.
The low beam light bulb is a H7 if im correct.
bs
Post by bs »
Sorted it! All I needed to know was that they are negative switched.
Both high and low go when highs are on now. And high beam light goes to.
But should I run a relay? Or would the standard relay be fine?
And should I change the fuse to a 20amp as suggested in the link above?
Steven
Post Reply
