I am new to this forum, and have tried searching to see if anyone has come up with a solution, or had this problem but couldn't really find any solid info. I have recently brought a 97 BZR Trueno, only done 100,000kms, drives like a dream but am worried about a abnormally loud ticking noise coming from the injectors once engine running at optimum temperature. Firstly being paranoid seen as I'd just brought the car I was thinking the worste case senario such as rod knock or something, but listening carefully, the noise sounds like its coming from the injectors. Am pretty sure its not a tappet noise as I spent quite a while trying to trace the noise, plus changing to a higher quality oil + power up, the tappets (or lifters
Russ
