proof of power increace over factory for WOF?
ChaosAD
Post by ChaosAD »
I have changed the cylinder head, intake and exhaust from the standard bluertop parts to silvertop.
My wof issuer wants to see proof that this has not caused a power increase of over 20%.
Whats the best way to prove this short of doing before/after dyno runs?
KwS
Post by KwS »
when i got asked for one in my subaru (went from TT GTB engine to single turbo STI engine, which are both the same rated power output), i got one of the guys at the subaru agent down here to write a letter for me that said they both had the same power output.
The silvertop makes 40ish more hp than the bluetop, doesnt it? Thats over 20% more...
MR2BOY23
Post by MR2BOY23 »
It probably has increased that much
20% being only a 30hp jump
Heylin
Post by Heylin »
Jesus, ive been running 33% increase now for a year, 2 WOFs and nothing has been asked for.
Heylin
MR2BOY23
Post by MR2BOY23 »
I thought that 20% only applied if your swapping the engine? not modifying it
Mr.Phreak
Contact:
Post by Mr.Phreak »
You thought wrong
Post by l1ttle_d3vil »
yeah, technically you need a cert for pod filters/intake systems/exhaust systems etc, if the mods increase the power over the 20%, even if they are bolt on.
but your wof guy sounds a bit anal? :? have you asked him what will be sufficient proof for him? it would vary from person to person.
if you can't prove it i guess you'd have to pay for the mods to be certified so it's all legal. i'd rather just find another wof garage :wink:
1I1
Contact:
Post by 1I1 »
This is why you buy a 20v. You can mod away happily knowing that this won't be a problem :lol:
It's like the exhaust law - unless you can prove otherwise you're pretty much in the wrong
TRD Clicky >>Here
Contact:
Post by Bling »
l1ttle_d3vil wrote: i'd rather just find another wof garage :wink:
I'd do this a few times before I did anything else :lol:
neo
Contact:
Post by neo »
pfft, use my dyno graphs 8) from two different silvertops, just crop off the bottom
ChaosAD
Post by ChaosAD »
If I drop in a complete silvertop it needs a cert as it makes more power than the stock bluetop.
Or I can 'modify' my bluetop (swap cyl head, intake, exhaust, block, crank, rods, etc etc form a silvertop) up to a 20% power increase before needing a cert. But I need to prove it doesnt make more than 20% over factory.
I letter from toyota wouldnt help as they think a silvertop makes 165Hp.
Here are the wof rules for engines http://www.landtransport.govt.nz/certifiers/virm-in-service/general-13-v3.pdf
He really just want something in writing to cover his arse should he get audited or whatever.
I dont mind getting a cert, but not just yet as I still want to get a half cage, bigger brakes etc first.
Contact:
Post by deaf_rattle »
you need a cert because you have changed the cylinder head. Its in the rules somewhere.
I never worried about it as i was passing wofs with the 20v conversion. But in saying that, i was uninsured. Im sure i wouldve been wasting my money if i had insurance for it, as they wouldve gone over the car in the case of an incident.
Post by cat007 »
I have a cert for the GTE engine verses the original N/A
And now I'm 240% over the car's factory engine
hmmmmm
lol
B1NZ
Post by B1NZ »
just do a dyno run and then show him toyotas factory power figures, will 100% surely be lower than the quoted factory power figure :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
Post by Lloyd »
deaf_rattle wrote:you need a cert because you have changed the cylinder head. Its in the rules somewhere.
No you don't, and no its not
ChaosAD
Post by ChaosAD »
Check table 13-1-1 in the link I posted.
when modifying an engine a cert is needed if you have a power increace of over 20% from stock, fitting a turbo or supercharger, substituting a turbo or wastegate or re-chipping the ecu on turbo cars.
Looks like ill just have to do a power run on a dyno, not that it will really tell him $&#$% as its measured at the wheels with all the ancillary's fitted. If its too high ill just have to retard the timing until it drops enough or adjust one of the constants on the dyno.
Toyota quote 88kw at the flywheel for the bluetop from memory, i'm expecting the silvertop will make more than that at the wheels.
stalker
Post by stalker »
ChaosAD wrote:Toyota quote 88kw at the flywheel for the bluetop from memory, i'm expecting the silvertop will make more than that at the wheels.
My silvertop made 85Kw atw.....and thats after trumpets, link and exhaust
:lol:
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
ChaosAD
Post by ChaosAD »
:lol:
Yea? shouldn't an average one make about 90kwatw?
stalker
Post by stalker »
Thats what I thought also...but as was pointed out to me in my project section posts, Toyota grossly over quoted the power outputs of all their engines...plus the loss via the drivetrain and gearbox also kills it.
So take the quoted bluetop figures and a dyno of your engine...and at a guess, you will be fine. *just dont tell the wof guy about the overquoted power figures from Toyota*
Loudtoy
Post by Loudtoy »
:lol:
You find that bugger all of them make 80kw let alone 90 atw.
I had a freak one that made 94(see sig) with exhaust, intake and some fluffing around with the afm but i never saw another silvertop putting out more than 84 with only these things done to it so you'l probably be safe with that.
Another thought is if you get the factory quoted figures from toyota for the blue top and then dyno the current setup he'l probably want to be there or something as why would oyu want to swap to a motor with less power??
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Post Reply
