NZ Fastest toyota's down the strip....
can anyone tell me what is.....
NZ's Fastest 4wd toyota down the strip...........
NZ's Fastest 4 cylinder toyota.............
Re: NZ Fastest toyota's down the strip....
strx7 wrote:NZ's Fastest 4 cylinder toyota.............
IIRC no one has beaten the [T1MID] DX Corolla of 10.5 down the 1/4. Its a 4AGTE 20v.
As for fastest 4wd Toyota? As soon as someone runs a 12 with a GT4, probably them.
i seem to recall seeing somewhere, someone with a St215 GT-T ran a high 11?????
- h8wrxs
- Toyspeed Member
- Location: travelling to candy mountain with my magical leoplurodon
Al wrote:strx7 wrote:NZ's Fastest 4 cylinder toyota.............
doesnt bazdas levin do 9s?
The four seasons in Australia consist of "$$% it's hot", "Can you believe how $$% hot it is?", "I won't be in today because it is too $$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs wrote:Al wrote:strx7 wrote:NZ's Fastest 4 cylinder toyota.............
Barry ran 10.88
strx7 wrote:i seem to recall seeing somewhere, someone with a St215 GT-T ran a high 11?????
Thats damn quick for a ST215, fastest ive seen was a 12.7 at suprafest 08
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
2004 Honda SCV100
Al wrote:IIRC no one has beaten the [T1MID] DX Corolla of 10.5 down the 1/4. Its a 4AGTE 20v.
Hmm, sounds like a challenge.
Loking at going to a drag event in October,
as the last time I went we think the diff mounts were bent would be why it went slower with more power.
- Dell'Orto
- ** Moderator **
Wasnt there a 3SGTE'd KE30 in Auckland that has done a high 10?
That green spec performance 3SGTE starlet from christchurch ran a 10.40 not to long ago.
Edit: found video - http://www.youtube.com/watch?v=VCSL8zCYnjQ
2004 Honda SCV100
2004 Honda SCV100
GTTpower wrote:That green spec performance 3SGTE starlet from christchurch ran a 10.40 not to long ago.
is the driver of that car Mazin Shalash?
NZPC mag, mazin shalash - toyota starlet - 9.84 or is that as rotary powered starlet?
- Dell'Orto
- ** Moderator **
Nah Mazin's one is the rotary starlet.
GTTpower wrote:strx7 wrote:i seem to recall seeing somewhere, someone with a St215 GT-T ran a high 11?????
guess i'll have to that the 4wd corolla to meremere at some stage then.........
Suprised no GT4's have stepped up and run a quick time yet. Ones ive seen manage to only run mid to low 13s.
2004 Honda SCV100
2004 Honda SCV100
classique71 wrote:St205's run a stock 13.5 .. thats a good start ...
- dnalunchie
- Toyspeed Member
With a good launch i reckon theres at least 4 St205's i know of that could dip into the 12's ..
Talk to diss1dent about how hard it is to get a ST205 into the 12s. So hard he bought an EVO3 to do it.
Quirky wrote:Mates Celica did 12's with fairly limited number of mods.
Ecu, injectors, fuel pump, gt30 turbo on 30psi.
Engine lasted a good 6 months worth of thrashing.
LOL you make that sound like those are good times for the mods!! You can go fast for few mods if you are willing to play with fire, 30psi through a GT30 to run 12s in a AWD is a bit of a shocker imho
That GT4 from Welly with "SAXMOS" as the plate was probably capable of respectable times, I saw that getting its beans once and it picked up speed quite rapidly - I'd believe that to be a low 12s car.
I'm also interested to see how Anth_555's GT4 goes once its done.
2007 Mazdaspeed Axela
