i am in the process of putting a 5 speed into my ke30. it is going in the place of a k40 and i have had 2 starlet k50's in it in the past with no issues but this time its a ke70 (rear shifter) box. however i have found some of the bellhousing bolt holes are in different places and the gearbox mount mounting points are completely different, more like a t50 mount setup.
are all k40's and k50's the same? i was lead to believe they were.
im confused as to why they are different. some of the bolt holes dont line up with anything.
im running a 4k witch i believe is from a ke70.
any ideas?
k50 diferances?
- 79rolla
- Toyspeed Member
k50 diferances?
past: AE82 FXGT
past: AE82 FXGT
- Dell'Orto
- ** Moderator **
If its got different bellhousing bolt pattersn, then its probably an A series K50. Take a photo and post it up for confirmation.
- 79rolla
- Toyspeed Member
ok just had a look on google and it is an a series k50. dammit just had it rebult aswell
is it worth selling it or just useing it with as many bolts as i can get in? and im hopeing the mount off of my t50 will fit because i want to use the car in the weekend.
past: AE82 FXGT
past: AE82 FXGT
- Dell'Orto
- ** Moderator **
Dude if you've had it rebuilt, you've probably got a gearbox you can hock for near on $500
People pay silly money for A series K50's.
