4age 20 ST injectors into BT Quads?
Post Reply
Lurkin
Post by Lurkin »
Interested to know if ST injectors can be fitted to a set of BT quads?
Past casualties
1986 4age liftback (sold)
Re: 4age 20 ST injectors into BT Quads?
Post by sergei »
Lurkin wrote:Interested to know if ST injectors can be fitted to a set of BT quads?
Yes. They are identical in fitting, cc/min and plugs.
Although ST injectors (pre-facelift) are worse in spray pattern.
neo
Contact:
Post by neo »
So if one has spare blacktop injectors and a silvertop engine, they should put the blacktop injectors in :)
Lurkin
Post by Lurkin »
on that note Neil,
have you seen this? its Matts bonnet (XSVWGN). will remove weight from the front end of you car/ its exceptionally cheap at that price!
http://www.trademe.co.nz/motors/car-par ... 118300.htm
Past casualties
Post Reply
