2ZZ into AE92
- Santa'sBoostinSleigh
- ** Moderator **
- Contact:
2ZZ into AE92
how hard is it to get a 2ZZ (with lift) installed into an AE92?
what gearbox/axles etc would you need to use?
any idea what the 2ZZ's and appropriate manual boxes go for roughly?
chur!
chur!
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
- Dell'Orto
- ** Moderator **
Your blacktop siezed?
- ** Moderator **
- Contact:
no, just weighing up options!
Santa's Mega Sale
- captain crescent
- Toyspeed Member
Google will lead you to a page where a guy has done it (I've been linked to it myself at one stage).
Also you could use PsychoHamster's AW11 build for some guidelines.
Looks like a pretty major mission ... have you even used your race car? If not, do you really want a three year build process before you have a play car ... [devil's advocate]
- 1I1
- Toyspeed Sponsor
- Contact:
http://www.youtube.com/watch?v=4B9jTh8KPyQ
That is all
But as per Leon's post, theres a few people that have done this. Re-use your C52 mounts on the C60, then just make an adaptor for the mount up by the timing cover
That is all
TRD Clicky >>Here
mark@manawatu.toyota.co.nz (Please mention Toyspeed
TRD Clicky >>Here
easily done.
Guy in aussie I know just did one.
He used the 4age C series box, and made an adapter plate for the drivers side eng mount.
Everything else just bolted up when using the c series 4age box.
One thing I found when test driving a couple of the 2zzge Corolla's, was that it was only just barely possible to keep the !@()@)#ing car on the @)#)@(#ing cam.
Is that situation improved or made worse by use of the C series 4AGE box?
Don't get me wrong here, I've got an AE92 club car currently running a silvertop, and one of the first things I thought when driving a 2zz was "Faaaaaaaaark this would be fun in my car". But then I started wondering about the gear ratios issue.
What are people's thoughts on the subject?
- 1I1
- Toyspeed Sponsor
- Contact:
You're not alone there re coming off lift. Drove Craig's (bones_on_bikes) RunX and found that / being a passenger also it annoyed me that Toyota seemed to do something stupid like this.
If doing a conversion factor in a ECU upgrade and then you can drop the lift point to make it more "usable".
TRD Clicky >>Here
TRD Clicky >>Here
- ** Moderator **
- Contact:
my plan would be to run an aftermarket ECU in my case anyway
Leon: its been years since this bastard has driven anyway, whats another 3 years?@?@
its got the blacktop sitting in there now, but its not wired up. brand new G3 link is still in box from 2+ years ago
figured blacktop isnt powerful enough for decent events, so figured 2zz might be next option!
Santa's Mega Sale
- flying_wedge
- Toyspeed Member
- Mr Revhead
- SECURITY!
- Contact:
1I1 wrote:You're not alone there re coming off lift. Drove Craig's (bones_on_bikes) RunX and found that / being a passenger also it annoyed me that Toyota seemed to do something stupid like this.
I wonder what that would feel like.
The lift switch point is bang on where the two cam profiles torque curves overlap
Taken from another forum.
Made some small modifications to the top AE82 gearbox mount base plate and bolted up the other AE82 brackets, then threw the box in the bay to check fitment. Plate mods involved slotting holes and using an end-mill to make a flat surface for the bolt heads.
Found out that the webbing on the 2zz sump fouls on the AE82 crossmember, so sectioned the crossmember. This pic shows the sectioned area ready to be plated up:
With that done I bolted the engine in to check the rest of the fitment. Found that the head fouls on the brake master cylinder, so will be retrofitting a ZZE122 non ABS brake master and possibly booster also which will solve the clearance issue:
I cut the metal part off the AE82 insulator that held the studs and tacked on a bit of 20mm square bar.
Then milled some recesses for the bolt heads in the zze123 alloy bracket, drilled some 10mm holes and turned up a locating sleeve that allowed me to accurately drill the required 8.5mm holes for the M10x1.25 tap:
Holes were then tapped and the mount is basically done. Will remove the insulator tomorrow, trim the excess bar and weld in webbing to reinforce it, then a sandblast and coat of paint will have it finished.
Finished off the timing cover mount parts, sandblasted the alloy section and painted the steel insulator, also sat the AE112 booster and master in place and the master has a ton of clearance to the head:
Skip forward a few pages:
- Dell'Orto
- ** Moderator **
Mr Revhead wrote:1I1 wrote:You're not alone there re coming off lift. Drove Craig's (bones_on_bikes) RunX and found that / being a passenger also it annoyed me that Toyota seemed to do something stupid like this.
Maybe a little less lightswitchy?
- 1I1
- Toyspeed Sponsor
- Contact:
Will let you know once bones_on_bikes does this to his race car Allex. He's in the process of getting the parts required together to alter it.
TRD Clicky >>Here
TRD Clicky >>Here
- Mr Revhead
- SECURITY!
- Contact:
I manage to speak to Lynn Rogers when he was doing the TRS engines and he told me they played with different switch points and the stock setting was the best.
Then again the gear ratios in those would allow it to stay on cam more.
It might feel more comfortable. But I reckon speed would suffer. How much? Who knows! Might help drivebility in corners though.
keep blacktop,
drive it heaps until you're feeling the need for more speed
spend $ on tubro
buy new trousers as required
Better power/value for your $ because you're not reinventing the wheel
And tubro always gives better value for money!
spend $ on tubro
