Tiptronics
Post Reply
FST4RD
Tiptronics
Post by FST4RD »
So I have been thinking about tiptronics.
Has anyone tried to reprogram one to make it shift faster, make it more manualised, make able to shift into neutral etc just using the + & - so that the gear box is more like a sequential and able to leave it in + - all the time?
I'm sure if you can have an aftermarket computer to run the engine and everything that goes with it, that this could potentially be the same thing?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
Heylin
Post by Heylin »
BP Legacys are programmable, you can also get improved valve assembly for the 5EAT gearbox that dramatically increases shifting speed and performance.
Heylin
MAC_HATER
Post by MAC_HATER »
i think the BA on falcon's have something of a "learning" tiptronic
i dunno and could be talking out of my ass but i borrowed my dad's BA Falcon for a week (he never uses the tiptronic or exceeds 2500rpm) where as i did use the tiptronic and made the car see the redline whenever legally possible
got a call some time after giving it back "the $&#$% did you do it it - it thinks its a bloody racecar chopping right down and revving its tits off whenever i give it some jandal!"
it either needed the cobwebs blowing out or it "gets used" to a drivers habits?
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
FST4RD
Post by FST4RD »
I was reading about an Evo 7 GTA in Japan where they had played with the box and made it almost like a proper clutchless sequential. It only shifted when you flicked the gear lever, it was a lot faster in the change as well. Don't think they modified the internals either, more of an ecu thing. Would be kinda cool to have something like that.
rolla_fxgt
Post by rolla_fxgt »
I thought most of the triptronics "learnt" your driving habits, and adjusted to suit. At least most of the newer ones anyway.
saft
Post by saft »
027 516 0556
I f**king love cheeseburgers.
AE82 FXGT
Post by AE82 FXGT »
MAC_HATER wrote:i think the BA on falcon's have something of a "learning" tiptronic
True, they do learn, it was from BA onwards, as said above, most new tiptronics do. Still can't beat the feel of a manual box.
FST4RD
Post by FST4RD »
saft wrote:http://www.powertraincontrolsolutions.com/transcontrol.php
That is very cool, that's more like it.
The old man had a late model turbo rvr with tiptronic box. I was thinking that if it shifted quicker, and when in tiptronic mode only shifted when you said to, as well as being able to shift into neutral and back into first so you could launch it would be pretty good.
I know the evo 10 is much like that.
Was just toying with the idea as my starion race car project is getting to the gear box stage of what I'm going to use.
FST4RD
Post by FST4RD »
100% agree, although I would love a sequential box for the race car.
Emperor
Contact:
Post by Emperor »
Nissans, in particular V35/M35 are learning Tiptronics also.
Guys in Aussie were reprogramming them for faster shifting though.
Also not sure if they do a kit for any other cars, but Works-Bell do a flappy paddle setup for Nissan tiptronics, convert your normal one in to carbon fibre paddles.
Edit - http://www.worksbell.co.jp/en/products/ ... paddle.htm
Contact:
Post by iOnic »
It *can* be done...but I wouldn't go there.
I don't recommend launching a tiptronic, turbo, AWD RVR. They are nothing like an Evo 10. The Evo X has a Getrag sequential twin clutch manual transmission that happens to have an automated shifting mode. It's not an automatic or tiptronic gearbox.
What you're asking about will absolutely destroy the tiptronic auto box and repairing one costs almost as much as an RVR is worth nowadays. Been there done that with a 99 Legnum VR4. If you want it to hold the revs a bit, reset the ECU and take it for a good thrash while it's relearning (I assume that the RVR has the INVECS-II trans?).
Not much point revving high anyway, power drops off very quickly because the boost tapers off after about 5000rpm on the stock tune.They're built/tuned for midrange punch not necessarily for top end.
FST4RD
Post by FST4RD »
I wouldn't do it to the RVR, I was thinking if I came across a RWD box that I could fit to the Starion and it could do what I wanted I would consider it.
kim0663
Post by kim0663 »
Planetary gearsets inside auto boxes are not designed to withstand shock either. From neutral to drive, in full power...
Why not use a high stall torque converter? Would be similar to launching.
Mr2 GT-S
330ci M
FST4RD
Post by FST4RD »
Thanks for all the info guys.
Sounds like the thoughts in my head were wrong :lol:
I'll probably just go for a w5* or rx7 series 4 or 5 box.
Contact:
Post by iOnic »
If you want sequential shifting, look at the Ikeya Formula shifter. Could possibly adapt it to work with what you want.
Post Reply
